How to define hatch boundary with Ellipse using Internal point
vkpunique
Message 1 of 1
vkpunique
I have this Cylinder like shape drawn using two Ellipse on top and bottom connected using lines. I want to fill this area with hatch.
here is my sample code, which is working. But I want to do this using internal point.
[CommandMethod("Test", CommandFlags.UsePickSet)]
public static void Test()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
        BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
        // Define the center point, major axis, and minor axis
        Point3d centerBottom = new Point3d(0, 0, 0);
        Point3d centerTop = new Point3d(0, 1000, 0);
        Vector3d majorAxis = new Vector3d(500, 0, 0);
        double minorAxisLength = 300;
        double radiusRatio = minorAxisLength / majorAxis.Length;
        // Create the ellipse at bottom
        Ellipse ellipseBottom = new Ellipse(centerBottom, Vector3d.ZAxis, majorAxis, radiusRatio, Math.PI, 2 * Math.PI);
        btr.AppendEntity(ellipseBottom);
        tr.AddNewlyCreatedDBObject(ellipseBottom, true);
        // Create the ellipse at top
        Ellipse ellipseTop = new Ellipse(centerTop, Vector3d.ZAxis, majorAxis, radiusRatio, Math.PI, 2 * Math.PI);
        btr.AppendEntity(ellipseTop);
        tr.AddNewlyCreatedDBObject(ellipseTop, true);
        Line leftLine = new Line(ellipseTop.StartPoint, ellipseBottom.StartPoint);
        btr.AppendEntity(leftLine);
        tr.AddNewlyCreatedDBObject(leftLine, true);
        Line rightLine = new Line(ellipseTop.EndPoint, ellipseBottom.EndPoint);
        btr.AppendEntity(rightLine);
        tr.AddNewlyCreatedDBObject(rightLine, true);
        ObjectIdCollection acObjIdColl = new ObjectIdCollection();
        acObjIdColl.Add(ellipseBottom.ObjectId);
        acObjIdColl.Add(leftLine.ObjectId);
        acObjIdColl.Add(ellipseTop.ObjectId);
        acObjIdColl.Add(rightLine.ObjectId);
        // Create the hatch object and append it to the block table record
        using (Hatch acHatch = new Hatch())
            btr.AppendEntity(acHatch);
            tr.AddNewlyCreatedDBObject(acHatch, true);
            // Set the properties of the hatch object
            // Associative must be set after the hatch object is appended to the
            // block table record and before AppendLoop
            acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
            acHatch.Associative = true;
            acHatch.PatternScale = 500;
            acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
            acHatch.EvaluateHatch(true);
        // Commit the transaction
        tr.Commit();
Replies (0)
