How to Customize Design Review ActiveX Control in .Net Form
I have a simple C# WinForms project (VS2010) that I have embedded the Design Review ActiveX control into.
1. Is it possible to remove the Home Markup & Measure Tool Resources menu bar or other menu items? Ideally, I would just like a rectangular preview window that is in pan/zoom mode.
2. The "Autodesk Design Review 2013 API Reference" help file 'adr2013_api.chm' does not display any content in Windows Help. I can see the table of contents in the Contents pane fine, but when I double click on anything in the Contents pane, nothing gets displayed in the right pane - it remains blank.
Thank you,
Warren
m_latz
That the contents are displayed, the .chm file must be located on your local harddrive (no network location).
If then the contents are not displayed. Right click the file and at the general tab of the file properties select "unblock". Then it should work.
regards
Markus
