How to create toolbar (C# objectArx)
Hi
How ca I create a simple autocad map toolbar with one button with one button by using Dot net object arx(C#).
I do not want to use COM interface objects.
Murali
Alexander.Rivilis
There are two ways:
1. COM - interface
2. CUI/CUIX - interface
Examples of both can be found on this forum.
Facebook | Twitter | LinkedIn
Expert Elite Member
Would u pls send me the example (CUI based toolbar having one button).
Actually It is very tedious job 4 me to extract my interest of code.
Thanks a lot!
Murali
Alexander.Rivilis
Search CUISAMP
Expert Elite Member
Actually what I want to do is :
I have one dot net arx dll. I have to create a setup so that any autocad Map user can install it .After installing The user can load the dll. On loadng Toolbar with one button must be appear. If I do it with .mns file I have to hardcode the button icon path.
Murali
