This code can help you:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(InsertShape.MyCommands))]
namespace InsertShape
public class MyCommands
[CommandMethod("InsertShape")]
public void MyCommand() // This method can have any name
// Put your command code here
Document doc = Application.DocumentManager.MdiActiveDocument;
if (doc == null)
return;
Editor ed = doc.Editor;
Database db = doc.Database;
PromptStringOptions prStr =
new PromptStringOptions("\nshx-file name: ");
prStr.AllowSpaces = true;
prStr.DefaultValue = "ltypeshp.shx";
PromptResult rsStr = ed.GetString(prStr);
if (rsStr.Status != PromptStatus.OK)
return;
string shxFilename = rsStr.StringResult;
try
shxFilename = HostApplicationServices.Current
.FindFile(shxFilename, db, FindFileHint.FontFile);
} catch
ed.WriteMessage("\nShx-file not found!");
return;
prStr.DefaultValue = "BOX";
prStr.Message = "\nShape name: ";
return;
string shapeName = rsStr.StringResult;
PromptPointResult rsPnt =
ed.GetPoint("\nInsert point: ");
if (rsPnt.Status != PromptStatus.OK)
return;
using (Transaction tr = doc.TransactionManager.StartTransaction())
TextStyleTable tst = tr.GetObject(db.TextStyleTableId, OpenMode.ForWrite) as TextStyleTable;
ObjectId styleId = GetObjectIdOfTextStyle(tst, shxFilename, tr);
if (styleId.IsNull)
TextStyleTableRecord tstr = new TextStyleTableRecord();
tstr.IsShapeFile = true;
tstr.FileName = shxFilename;
styleId = tst.Add(tstr);
tr.AddNewlyCreatedDBObject(tstr, true);
Shape shape = new Shape(rsPnt.Value, 1.0, 0.0, 1.0);
shape.SetDatabaseDefaults(db);
shape.StyleId = styleId;
BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
btr.AppendEntity(shape);
shape.Name = shapeName;
tr.AddNewlyCreatedDBObject(shape, true);
tr.Commit();
public static ObjectId GetObjectIdOfTextStyle(TextStyleTable tst, string shxFileName, Transaction tr)
foreach (ObjectId idtsr in tst)
tr.GetObject(idtsr, OpenMode.ForRead) as TextStyleTableRecord;
if (shxFileName.ToLower() == tstr.FileName.ToLower())
return tstr.ObjectId;
return ObjectId.Null;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
