C# Create LineTypeStyle in code with symbol SHX autocad
Message 1 of 1
How to create a line style in the c # code by using Shape (shp) from the *.shx file. Kean Walmsley Creating a complex AutoCAD linetype containing text using .NET shows how to make a line style with text. I care about the line style with the shp symbol.
In the *.lin file it is saved by:
*ZIG,Zig zag
A,0,[Zig,Shapes.shx,X=0,Y=0.15],-2.5,
Example by Kean for line style with text
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
namespace Linetype
  public class Commands
    [CommandMethod("CCL")]
    public void CreateComplexLinetype()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        // We'll use the textstyle table to access
        // the "Standard" textstyle for our text
        // segment
        TextStyleTable tt =
          (TextStyleTable)tr.GetObject(
            db.TextStyleTableId,
            OpenMode.ForRead
        // Get the linetype table from the drawing
        LinetypeTable lt =
          (LinetypeTable)tr.GetObject(
            db.LinetypeTableId,
            OpenMode.ForWrite
        // Create our new linetype table record...
        LinetypeTableRecord ltr =
          new LinetypeTableRecord();
        // ... and set its properties
        ltr.Name = "COLD_WATER_SUPPLY";
        ltr.AsciiDescription =
          "Cold water supply ---- CW ---- CW ---- CW ----";
        ltr.PatternLength = 0.9;
        ltr.NumDashes = 3;
        // Dash #1
        ltr.SetDashLengthAt(0, 0.5);
        // Dash #2
        ltr.SetDashLengthAt(1, -0.2);
        ltr.SetShapeStyleAt(1, tt["Standard"]);
        ltr.SetShapeNumberAt(1, 0);
        ltr.SetShapeOffsetAt(1, new Vector2d(-0.1,-0.05));
        ltr.SetShapeScaleAt(1, 0.1);
        ltr.SetShapeIsUcsOrientedAt(1, false);
        ltr.SetShapeRotationAt(1, 0);
        ltr.SetTextAt(1, "CW");
        // Dash #3
        ltr.SetDashLengthAt(2, -0.2);
        // Add the new linetype to the linetype table
        ObjectId ltId = lt.Add(ltr);
        tr.AddNewlyCreatedDBObject(ltr, true);
        // Create a test line with this linetype
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId,
            OpenMode.ForRead
        BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            bt[BlockTableRecord.ModelSpace],
            OpenMode.ForWrite
        Line ln =
          new Line(
            new Point3d(0, 0, 0),
            new Point3d(10, 10, 0)
        ln.SetDatabaseDefaults(db);
        ln.LinetypeId = ltId;
        btr.AppendEntity(ln);
        tr.AddNewlyCreatedDBObject(ln, true);
        tr.Commit();
How to add shp from shx file instead of text?
Please help!
Replies (0)
