How to create a "TextStyles" using the font "romans.shx"?
I'm having problems to create "TextStyles" with the sources of AutoCad.
I am using the following methods:
 public static ObjectId CreateTexstyle(Configuration conf)
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                TextStyleTable textStyleTable = (TextStyleTable)acTrans.GetObject(acCurDb.TextStyleTableId, OpenMode.ForRead);
                TextStyleTableRecord textStyleTableRecord = null;
                if (textStyleTable.Has(conf.EXTTEXTStyleName) == false)
                    if (textStyleTable.IsWriteEnabled == false)
                        textStyleTable.UpgradeOpen();
                    textStyleTableRecord = new TextStyleTableRecord();
                    textStyleTableRecord.Name = conf.EXTTEXTStyleName;
                    textStyleTable.Add(textStyleTableRecord);
                    acTrans.AddNewlyCreatedDBObject(textStyleTableRecord, true);
                else
                    textStyleTableRecord = acTrans.GetObject(textStyleTable[conf.EXTTEXTStyleName],
                        OpenMode.ForWrite) as TextStyleTableRecord;
                textStyleTableRecord.XScale = conf.EXTTEXTFactor;
                textStyleTableRecord.TextSize = conf.EXTTEXTSize;
                textStyleTableRecord.Font = UpdateTextFont(conf.EXTTEXTFont, conf.EXTTEXTFontItalico, conf.EXTTEXTFontNegrito);
                acTrans.Commit();
                return textStyleTableRecord.ObjectId;
        public static Autodesk.AutoCAD.GraphicsInterface.FontDescriptor UpdateTextFont(string font, bool italic, bool negrito)
            return new Autodesk.AutoCAD.GraphicsInterface.FontDescriptor(font, negrito, italic, 0, 0);
In the example font = "romans", italic = false end bold = false.
In AutoCad the source is "romans.shx" but is a little different from when it is configured manually.
Programmatically
manually
Note that the text becomes thicker.
And a little change settings window TextStyles. What can be?
I managed to solve the problem.
Add the following line in the code:
textStyleTableRecord.FileName = conf.EXTTEXTFont + ".shx";
                else
                acTrans.Commit();
 Now I have another problem.
My program offers options for Windows font, I believe it has not equivalent for all sources in the autocad file extension "*. shx", then how could verify this?
If there is "*. shx" to use that font "*. shx", if not use defaut.
That way it worked, I do not know if it is guaranteed: Smiley Indifferent
                if(File.Exists(AppDomain.CurrentDomain.BaseDirectory + "Fonts\\" + conf.EXTTEXTFont + ".shx"))
Thank you!
Alexander.Rivilis
@Anonymous wrote:
... I do not know if it is guaranteed: ...
It will be guaranteed if you check directory of dwg-file and AutoCAD support pathes.
Facebook | Twitter | LinkedIn
Expert Elite Member
How do I do that?
Alexander.Rivilis
With help of HostApplicationServices.FindFile method
Expert Elite Member
