How to change Layer's Transparency?
MGOMKD
MGOMKD
Is it able to change the transparency of a layer?
I know how to get the value but i can't find how to set a new one!
Using acTrans = acDocs.MdiActiveDocument.Database.TransactionManager.StartTransaction()
            acLyrTbl = acTrans.GetObject(acDocs.MdiActiveDocument.Database.LayerTableId, OpenMode.ForRead)
            For Each acObjId As ObjectId In acLyrTbl
                acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead)
                Dim MyTransparency As Autodesk.AutoCAD.Colors.Transparency = acLyrTblRec.Transparency
                MsgBox(MyTransparency.ToString)
            Next acObjId
End Using
 Dev center is a little bit poor about it? Or I didn't it!
Hallex
See article here
http://adndevblog.typepad.com/autocad/2012/04/setting-layer-transparency.html
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
MGOMKD
Hi!
I'm progressing on changing layer's transparency. I noticed that transparencies are changed in the layer manager but not in the modelspace! Is there a way to refresh this? I tried REGEN and REFRESH but it doesn'twork!
Here is my code
'Déclaration des variables'
        acDoc = Application.DocumentManager.MdiActiveDocument
        acCurDb = acDoc.Database
        'Procédure'
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
            If acLyrTbl.Has(LayerVal) = True Then
                acCurDb.Clayer = acLyrTbl(LayerVal)
                    acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForWrite)
                    If acLyrTblRec.Name <> LayerVal Then
                        acLyrTblRec.Transparency = New Autodesk.AutoCAD.Colors.Transparency(CByte(50))
                    End If
                Next (acObjId)
                acTrans.Commit()
            End If
        End Using
 This code turns the layer named layerval current, then iterate through layers collection and change their transparency if layer's name is different of Layerval.
Quietly but surely!
See you!
Hallex
Me too didn't solve this issue, sorry
~'J'~
Alfred.NESWADBA
I also can reproduce the problem (AutoCAD 2012 x64 SP2 German).
The only way I currently found out is:
  • run your proc
  • change to any layout other than modelspace
  • change back to modelspace
It's a bad workaround, but at least it is one 😉
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
MGOMKD
Hi friends!
I confirm, toggling from modelspace to layouts then getting back to modelspace works! But it's not the way I expected,
It should exist an easier one!
Go for it !!!
See you.
MGOMKD
Hi friends,
By searching on the web and the .NET Developper's guide, I found a way to refresh layer after transparencies had changed.
Here's the source code:
 Public Sub CurrentLayer(ByVal LayerVal)
        '* Activation du calque séléctionné en calque courant et gestion de la transparence *'
        Dim acObjId As ObjectId
        'Procédure'
        Using acTrans = acCurDb.TransactionManager.StartTransaction()
                For Each acObjId In acLyrTbl
                        'Transparence du calque à 80'
                    Else
                        'Transparence du calque à 0'
                        acLyrTblRec.Transparency = New Autodesk.AutoCAD.Colors.Transparency(CByte(255))
                    End If
                Next (acObjId)
            End If
            'Application des changements'
            acTrans.Commit()
            'Déclaration variable et appel de fonction'
            Dim acLyrTblIds As ObjectIdCollection = GetLayerObjectIds()
            'Itération sur les calques dans la collection'
            Dim acLyrTblId(acLyrTblIds.Count - 1) As ObjectId
            For i = 0 To acLyrTblIds.Count - 1
                acLyrTblId(i) = acLyrTblIds(i)
            Next
            'Regénération des calques'
            Autodesk.AutoCAD.Internal.LayerUtilities.RegenLayers(acLyrTblId, Autodesk.AutoCAD.Internal.LayerUtilities.RegenPending)
        End Using
    End Sub
    Function GetLayerObjectIds() As ObjectIdCollection
        '* Création du stockage de la collection de calques *'
        'Déclaration variable'
        Dim acLyrTblIds As New ObjectIdCollection
        'Procédure'
            acLyrTbl = acCurDb.LayerTableId.GetObject(OpenMode.ForWrite)
            'Création de la collection de calques'
                acLyrTblIds.Add(acObjId)
            Next
            acTrans.Commit()
        End Using
        'Renvoi du résultat'
        Return acLyrTblIds
    End Function
 See you!
