How to change elevation from code
mecoman6GF27
mecoman6GF27
Hi everyone.
Is it possible from code to change the elevation value and, based on its value, add a text at the bottom of AutoCAD?
Thanks bye.
Gepaha
Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("ELEVATION")
If I interpreted it correctly it already appears.
mecoman6GF27
Hi, thanks for the reply.
On the elevation value I solved but below (exactly where you posted the image) I have to add a text based on the elevation value.
hippe013
Are you referring to the MODEMACRO system variable? This allows a user to display some text on the status bar.
Type MODEMACRO on the command line and enter a piece of text. This will then be displayed on the bottom of the Window.
Example: MODEMACRO
HELLO WORLD!
Gepaha
If you find it really necessary, you can add your own items to the StatusBar.
I think I would have to find the item containing elevation and replace it.
There are examples on the internet.
mecoman6GF27
Hello and thanks a lot for the help
