How to batch fix errors in side database?
swaywood
swaywood
I use command audit,but failed.
    [CommandMethod("Q11")]
    public void Q11()
      Database db = HostApplicationServices.WorkingDatabase;
      Document doc = AcadApp.DocumentManager.MdiActiveDocument;
      string sFolder = @"c:\test";
      DirectoryInfo folder = new DirectoryInfo(sFolder);
      FileInfo[] chldFiles = folder.GetFiles("*.dwg");
      using (Transaction trans = db.TransactionManager.StartTransaction())
        foreach (FileInfo fi in chldFiles)
          string sDwg = fi.FullName;
          try
            using (Database dbInsert = new Database(false, false))
              dbInsert.ReadDwgFile(sDwg, System.IO.FileShare.ReadWrite, true, null);
              AcadApp.DocumentManager.GetDocument(dbInsert).Editor.Command("audit", "y");
              dbInsert.SaveAs(sDwg, DwgVersion.AC1027);
          catch
        trans.Commit();
_gile
You cannot call Editor.Command in a side database as you do not have acces to the Editor.
You can try the DatabaseExtension.Audit method.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
swaywood
GILE, THANKS AGAIN!
