How to apply sheet properties modifications to drawings
ahmedshawkey95
Message 1 of 1
ahmedshawkey95
Hi All,
I'm developing an automation plugin that allows me to modify properties of some Sheets in a selected Sheet Set at once using WPF window as shown below, and the following code updates the Description property for all sheets but when I tried to open sheet properties from AutoCAD, it shows the old value thus the attributes fields that use this property don't change.
How to apply or sync my changes to the drawings?
 private void BtnOk_OnClick(object sender, RoutedEventArgs e)
            AcSmSheetSetMgr mgr = new AcSmSheetSetMgr();
            AcSmDatabase db;
            try
                db = mgr.OpenDatabase(_activeSheetSetPath, false);
            catch (System.Exception ex)
                MessageBox.Show(ex.Message,
                    "Can't Open Sheet Set", MessageBoxButton.OK, MessageBoxImage.Exclamation);
                return;
            if (db.GetLockStatus() != AcSmLockStatus.AcSmLockStatus_UnLocked)
                MessageBox.Show($"The selected sheet set is already opened by another task. Try to close it first.",
                    "Sheet Set Is Locked", MessageBoxButton.OK, MessageBoxImage.Exclamation);
                return;
            db.LockDb(db);
            AcSmSheetSet ss = db.GetSheetSet();
            //var allItems = _viewModel.Items.SelectMany(i => i.GetAllChildren()).ToList();
            var iterator = ss.GetSheetEnumerator();
            IAcSmComponent item = iterator.Next();
            while (item != null)
                //Here I'm updating all properties and custom properties but I changed it for simplicity
                if (item is AcSmSheet sheet)
                    sheet.SetDesc("Updated Description");//this line updates the sheet description but doesn't affect the sheet properties form in AutoCAD
            db.UnlockDb(db, true);
            mgr.Close(db);
            Close();
Replies (0)
