How do i access DGN export Standard Mapping Setup in API, by c# code
official.jaydeo
official.jaydeo
Hi all,
I am trying to create app that has some Automation task where i need to set DGN Export Setup such as Layer to Level naming , Text Setting and Line weight Settings.
how do i access same in API , in code snippet or advice will be helpful....
i want do this but programmatically
is it posible?
@_gile  @kerry_w_brown
norman.yuan
There is no API exposed in AutoCAD .NET API (or COM, ObjectARX C++, for that matter) to export/convert DWG to DNG. You'll need to look for third party apps/components. I would write my DNG<=>DWG converting app against cloud services, such as this:
https://mygeodata.cloud/
Norman Yuan
Drive CAD With Code
