how can i use the current usc
Amremad
Message 1 of 9
Amremad
Dim OPoint As Point3d = New Point3d(BlkRef.Position.X, BlkRef.Position.Y, BlkRef.Position.Z)
Dim NPoint As Point3d= New Point3d(BlkRef.Position.X, BlkRef.Position.Y+100, BlkRef.Position.Z)
BlkRef.TransformBy(Matrix3d.Displacement(OPoint.GetVectorTo(NPoint)))
 this is function to move my block from OPoint to NPoint , in Y direction
so if the ucs changed , my code use the old y direction not current you dirction
so how can i tell my code to take new y and x directions (current ucs)
Replies (8)
Message 2 of 9
Balaji_Ram
Can you please try this ?
' Moves by 10 units along WCS Y Axis
'Dim disp As Matrix3d = Matrix3d.Displacement(Vector3d.YAxis * 10.0)
' Moves by 10 units along UCS Y Axis
Dim disp As Matrix3d = Matrix3d.Displacement((Vector3d.YAxis * 10.0).TransformBy(ed.CurrentUserCoordinateSystem))
Dim nPt As Point3d = opt.Position.TransformBy(disp)
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
Amremad
i can't understand any thing ,
i have two block attribute , so i  move the block by difference between it's texts attributes
this is function that i need to edit it in my class  , see it
    Private Shared Sub ChangePostionLevel(MySelSet As SelectionSet, BPoint As Point2d, BValue As String, Unit As Double)
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        If MySelSet IsNot Nothing Then
            For Each BlKID In MySelSet.GetObjectIds()
                Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
                Dim objId As ObjectId = BlkRef.AttributeCollection.Item(0)
                Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForWrite)
                Dim ucs As Matrix3d = Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem
                If attRef.TextString > BValue Then
                    NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit), BlkRef.Position.Z)
                ElseIf attRef.TextString < BValue Then
                    NPoint = New Point3d(BlkRef.Position.X, (BPoint.Y - (Val(BValue) - Val(attRef.TextString)) * Unit), BlkRef.Position.Z)
                ElseIf attRef.TextString = BValue Then
                    'Dim NPoint As Point3d = New Point3d(BlkRef.Position.X, (BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit), BlkRef.Position.Z)
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
    End Sub
 i hope to correct it for me
Message 4 of 9
Balaji_Ram
To understand what I meant, please try this :
1. Open the attached drawing
2. Try running the following command and select the point. The point always moves along the UCS Y Axis by 10 units.
Change to a different UCS and try the command again.
        <CommandMethod("MP")> _
        Public Shared Sub MovePoint()
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
            Dim selectedEntity As PromptEntityResult = ed.GetEntity("Please select an point : ")
            Dim objectId As ObjectId = selectedEntity.ObjectId
            Try
                Using trans As Transaction = db.TransactionManager.StartTransaction()
                    Dim ent As Entity = TryCast(trans.GetObject(objectId, OpenMode.ForWrite), Entity)
                    If TypeOf ent Is DBPoint Then
                        Dim opt As DBPoint = TryCast(ent, DBPoint)
                        opt.Position = nPt
                    End If
                    trans.Commit()
                End Using
            Catch ex As System.Exception
                ed.WriteMessage(ex.Message)
            End Try
        End Sub
About correcting your code, I will need more info to understand the problem. Can you provide the drawing and explain what the expected / actual behavior is ?
Balaji
Message 5 of 9
Amremad
yes i understand you code
but i can't edit my code to get me what i want
see this is my try
    Private Shared Sub ChangePostionLevel(MySelSet As SelectionSet, BPoint As Point3d, BValue As String, Unit As Double)
                    Dim disp As Matrix3d = Matrix3d.Displacement((Vector3d.YAxis * (BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit)).TransformBy(ed.CurrentUserCoordinateSystem))
                    NPoint = BPoint.TransformBy(disp)
                    Dim disp As Matrix3d = Matrix3d.Displacement((Vector3d.YAxis * (BPoint.Y - (Val(BValue) - Val(attRef.TextString)) * Unit)).TransformBy(ed.CurrentUserCoordinateSystem))
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
    End Sub
 but don't give me the correct position for block
can you help me plz
Message 6 of 9
Balaji_Ram
Can you please provide a sample drawing to test with ?
Also I would like to know the parameters that you are using with "ChangePostionLevel" method.
If you can simply attach a buildable sample project and a simple test drawing, that would be help.
It is little hard for me to visualize the kind of displacement that you are trying to achieve for the block reference.
Balaji
Message 7 of 9
Amremad
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Public NotInheritable Class CheckLevels
    Public Shared Sub CheckLevel()
        Dim Unit As Double = Val(GetSetting("AMR LISP", "Check Level", "Unit", 1000))
        Dim Method As String = GetSetting("AMR LISP", "Check Level", "Method", "Custom")
        Dim LFormat As String = GetSetting("AMR LISP", "Check Level", "Format", "0.00")
        Dim LastMethod As String = GetSetting("AMR LISP", "Check Level", "LastMethod", "Change")
        Dim BPoint As Point3d, BValue As Double, BlockName As String
        Dim Trans As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        Dim AcEntOption As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select base block")
        AcEntOption.Keywords.Add("Unit")
        AcEntOption.Keywords.Add("Method")
        AcEntOption.Keywords.Add("Format")
        AcEntOption.SetRejectMessage(vbLf & "You must pick a block try again ...")
        AcEntOption.AddAllowedClass(GetType(BlockReference), False)
L1:     Dim AcEntResult As PromptEntityResult = Application.DocumentManager.MdiActiveDocument.Editor.GetEntity(AcEntOption)
        If AcEntResult.Status = PromptStatus.OK Then
            Dim BlkRef As BlockReference = Trans.GetObject(AcEntResult.ObjectId, OpenMode.ForRead)
            If (BlkRef.AttributeCollection.Count) > 0 Then
                Dim attRef As AttributeReference = Trans.GetObject(objId, OpenMode.ForRead)
                BValue = Val(attRef.TextString)
                BlockName = BlkRef.Name
                BPoint = New Point3d(BlkRef.Position.X, BlkRef.Position.Y, BlkRef.Position.Z)
            Else
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "you are selected invalid block doesn't have any attributes")
                Exit Sub
            End If
            ' start select blocks which we want to edit it
            ' create selection filter with typedvalues
            Dim TypedValues(0) As TypedValue
            TypedValues.SetValue(New TypedValue(DxfCode.BlockName, BlockName), 0)
            Dim AcSelFtr As SelectionFilter = New SelectionFilter(TypedValues)
            'create keywords options for selection
            Dim AcSelOption As PromptSelectionOptions = New PromptSelectionOptions
            AcSelOption.MessageForAdding = ("Select other (" & BlockName & ") blocks that you want to change")
            'start selectionset with keywords and filter
            Dim AcSelResult As PromptSelectionResult
            AcSelResult = Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(AcSelOption, AcSelFtr)
            If AcSelResult.Status = PromptStatus.OK Then
                Select Case Method
                    Case "Change"
                        ChangeTextLevel(AcSelResult.Value, BPoint, BValue, Unit, LFormat)
                    Case "Move"
                        ChangePostionLevel(AcSelResult.Value, BPoint, BValue, Unit)
                    Case "Custom"
                        Dim AcKwrdOption As PromptKeywordOptions = New PromptKeywordOptions(vbLf & "Which method will execute [Change/Move] : ", "Change Move")
                        AcKwrdOption.Keywords.Default = LastMethod
                        Dim AcKwrdResult As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetKeywords(AcKwrdOption)
                        If AcKwrdResult.Status = PromptStatus.OK Then
                            Select Case AcKwrdResult.StringResult
                                Case "Change"
                                Case "Move"
                            End Select
                            LastMethod = AcKwrdResult.StringResult
                            SaveSetting("AMR LISP", "Check Level", "LastMethod", LastMethod)
                        End If
                End Select
            End If
            ' end code
        ElseIf AcEntResult.Status = PromptStatus.Keyword Then
            Select Case AcEntResult.StringResult
                Case "Unit"
                    Dim AcDblOption As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "Enter the calculation unit (Meter Unit) ")
                    AcDblOption.AllowNone = False
                    AcDblOption.DefaultValue = Unit
                    AcDblOption.AllowNegative = False
                    Dim AcDblResult As PromptDoubleResult = Application.DocumentManager.MdiActiveDocument.Editor.GetDouble(AcDblOption)
                    If AcDblResult.Status = PromptStatus.OK Then
                        Unit = AcDblResult.Value
                        SaveSetting("AMR LISP", "Check Level", "Unit", Unit)
                        GoTo L1
                    End If
                    GoTo L1
                Case "Method"
                    Dim AcKwrdOption As PromptKeywordOptions = New PromptKeywordOptions(vbLf & "Which method you will use  [Change/Move/cuStom] : ", "Change Move Custom")
                    AcKwrdOption.Keywords.Default = Method
                        SaveSetting("AMR LISP", "Check Level", "Method", Method)
                    End If
                    GoTo L1
                Case "Format"
                    Dim AcStrOption As PromptStringOptions = New PromptStringOptions("Enter text format that you want :")
                    AcStrOption.DefaultValue = LFormat
                    Dim AcStrResult As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetString(AcStrOption)
                    If AcStrResult.Status = PromptStatus.OK Then
                        LFormat = AcStrResult.StringResult
                        SaveSetting("AMR LISP", "Check Level", "Format", LFormat)
                    End If
                    GoTo L1
            End Select
        End If
        Trans.Commit()
        Trans.Dispose()
    End Sub
    Private Shared Sub ChangeTextLevel(MySelSet As SelectionSet, BPoint As Point3d, BValue As String, Unit As Double, LFormat As String)
                If BlkRef.Position.Y > BPoint.Y Then
                    attRef.TextString = LevelFormat((BValue + (BlkRef.Position.Y - BPoint.Y) / Unit), LFormat)
                ElseIf BlkRef.Position.Y < BPoint.Y Then
                    attRef.TextString = LevelFormat((BValue - (BPoint.Y - BlkRef.Position.Y) / Unit), LFormat)
                ElseIf BlkRef.Position.Y = BPoint.Y Then
                    attRef.TextString = LevelFormat((BValue), LFormat)
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
    End Sub
    Private Shared Function LevelFormat(LValue As Double, LFormat As String) As String
        If LValue > 0 Then
            Return ("+" & Format(LValue, LFormat))
        ElseIf LValue < 0 Then
            Return (Format(LValue, LFormat))
        ElseIf LValue = 0 Then
            Return ("±" & Format(LValue, LFormat))
        Else
            Return ""
        End If
    End Function
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
    End Sub
End Class
 this is my all code , and i attaced level block atrribute
Message 8 of 9
Amremad
    <CommandMethod("CL")>
    Public Sub CheckMyLevel()
        CheckLevels.CheckLevel()
    End Sub
Message 9 of 9
Balaji_Ram
Thanks for providing more info.
In your original post, the displacement was by a constant 100 units which is not the case in your recent code sample.
The amount of displacement calculated using "(BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit)" may not be what you want actually when the UCS is changed.
Here is a part of your code sample that moves the selected block reference along the UCS Y direction. Depending on how you want to align the block references, you may have to change the distance.
            Using Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                        Dim yAxis As Vector3d
                        yAxis = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Yaxis
                        Dim distance As Double
                        ' Change the distance according to your requirement
                        distance = ((BPoint.Y + (Val(attRef.TextString) - Val(BValue)) * Unit) - BlkRef.Position.Y)
                        Dim dispVector As Vector3d = distance * yAxis
                        BlkRef.TransformBy(Matrix3d.Displacement(dispVector))
                    Next
                End If
                Tr.Commit()
            End Using
        End Sub
Balaji
