How can I select from screen
- Mute
- Permalink
- Report
Hi Guys,
I am using vb.net with AutoCAD 2010. What I am trying is do select object from screen with filter(XData filter)
When I use vb6 I use objsset.SelectOnScreen varType,varData
But in .net it seems not working
Any help
My code is
code is in a class
Public Sub func()'--Display message
m_objDrawing.Utility.Prompt("Please select fixtures you want to assign")
Try
'--Select Fixtures
objFixSSet = SelectionSetAdd(m_objDrawing,"temp") '--this is my function to add a selectionset
varType(0) = 1001
varData(0) = STR_XDATA_FIXTURE
objFixSSet.SelectOnScreen(varType, varData)
Dim objFixSSet As Autodesk.AutoCAD.Interop.AcadSelectionSet"TempFixture")Dim varType(0) As Integer, varData(0) As VariantTypeIf objFixSSet.Count = 0 Then
g_objDrawing.Utility.Prompt(
"Please select at least on fixture to assign to zone")Return
End If
MsgBox(objFixSSet.Count)
Catch ex As Exception
End Try End Sub
