Highlight part of polyline
Ertqwa
Message 1 of 11
Ertqwa
Hello Forum,
is it possible to highlight a part of a polyline in someway?
Thank you.
Replies (10)
Message 2 of 11
Hallex
Try thsi code
        [CommandMethod("Segh")]
        public void SegmentHighLight()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect the segment to copy: ");
            peo.SetRejectMessage("\nYou have to select polyline only!");
            peo.AllowNone = false;
            peo.AllowObjectOnLockedLayer = false;
            peo.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            ObjectId objId = per.ObjectId;
            if (!objId.ObjectClass.IsDerivedFrom( RXClass.GetClass(typeof(Polyline))))
                ed.WriteMessage(
                    "\nYou didn't select a lwpline, please try again...\n");
                return;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Polyline pline = tr.GetObject(objId, OpenMode.ForRead, false) as Polyline;
                    if (pline != null)
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false) as BlockTableRecord;
                        Point3d pickPt = pline.GetClosestPointTo((Point3d)per.PickedPoint, false);
                        double param = pline.GetParameterAtPoint(pickPt);
                        int num = (int)param + 1;
                        ObjectId[] subentIds = { };
                        FullSubentityPath[] ips = pline.GetSubentityPathsAtGraphicsMarker(SubentityType.Edge, num, pickPt, Matrix3d.Identity, 1, subentIds);
                        pline.Highlight(ips[0], true);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
            finally
                ed.WriteMessage("Pokey");
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
Ertqwa
Hi, ty for the response.
If I try your code,  get an error at the following line:
Error:
eNotApplicable at Autodesk.AutoCAD.DatabaseServices.Entity.Highlight(FullSubentityPath subId, Boolean highlightAll)
Trying to find out what it might be but no luck so far.
Message 4 of 11
Hallex
I tested code on A2010, it's  a reason maybe
Message 5 of 11
Ertqwa
Ah I see, I use AutoCAD2009. I'll do some more checking. Ty.
Message 6 of 11
Hallex
Here is another way, see maybe it will working on your release
        	using Autodesk.AutoCAD.ApplicationServices;
	using Autodesk.AutoCAD.DatabaseServices;
	using Autodesk.AutoCAD.EditorInput;
	using Autodesk.AutoCAD.Runtime;
	using Autodesk.AutoCAD.Geometry;
	using Autodesk.AutoCAD.GraphicsInterface;
	using Autodesk.AutoCAD.Colors;
	//_____________________________________//
        [CommandMethod("colseg")]
        public void ColoredSegment()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect Segment of Polyline:");
            peo.SetRejectMessage("\nMust be a Polyline!");
            peo.AddAllowedClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline), false);
                return;
            Transaction tr = db.TransactionManager.StartTransaction();
            Autodesk.AutoCAD.DatabaseServices.Polyline pl = new Autodesk.AutoCAD.DatabaseServices.Polyline();
            IntegerCollection ic = new IntegerCollection();
            using (tr)
                Autodesk.AutoCAD.DatabaseServices.Polyline pline = tr.GetObject(per.ObjectId, OpenMode.ForRead) as Autodesk.AutoCAD.DatabaseServices.Polyline;
                if (pline != null)
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(pline.OwnerId, OpenMode.ForWrite);
                    double bulg = 0;
                    Point3d picked = pline.GetClosestPointTo((Point3d)per.PickedPoint, false);
                    double par = pline.GetParameterAtPoint(picked);
                    int m = (int)par;
                    Point2dCollection verts = new Point2dCollection(2);
                    SegmentType stype = pline.GetSegmentType(m);
                    if (stype == SegmentType.Arc)
                        CircularArc2d arc = pline.GetArcSegment2dAt(m);
                        bulg = pline.GetBulgeAt(m);
                        verts.Add(arc.StartPoint);
                        verts.Add(arc.EndPoint);
                    else if (stype == SegmentType.Line)
                        LineSegment2d ln = pline.GetLineSegment2dAt(m);
                        verts.Add(ln.StartPoint);
                        verts.Add(ln.EndPoint);
                        bulg = 0;
                    pl.AddVertexAt(0, verts[0], bulg, 0, 0);
                    pl.AddVertexAt(1, verts[1], 0, 0, 0);
                    pl.ColorIndex = 121;
                    ObjectIdCollection ids = new ObjectIdCollection();
                    btr.AppendEntity(pl);
                    tr.AddNewlyCreatedDBObject(pl, true);
                    verts = new Point2dCollection();
                    if (pl != null)
                        TransientManager tm = TransientManager.CurrentTransientManager;
                        tm.AddTransient(pl, TransientDrawingMode.Highlight, 128, ic);
                if (pl != null)
                    pl.Erase();
                    pl.Dispose();// optional, might be removed
                tr.Commit();
                // pause for user input only
                string key = ed.GetString("\nPress any key: ").StringResult;
                TransientManager.CurrentTransientManager.EraseTransient(pline, ic);
~'J'~
Message 7 of 11
Ertqwa
Hi, that works, thanks a lot!
One question tho, if I leave out the "EraseTransient" line at the end, it still disapears after I regenerate. Why should I call it?
I'll try and see if I can get the other one to work.
Message 8 of 11
Hallex
I did it machinally, though it is no problem
to keep them  inside, but who knows?
Of course, if you need to display a segment
in the work time, then don't remove,
See you,
~'J'~
Message 9 of 11
conveyor1
Was wondering if anyone has a VB.net version of this code.  I am having some difficulty modifying it from C#.
Please let me know if you can.
Message 10 of 11
_gile
Have you simply tried a code converter?
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 11 of 11
Norman_Yuan
I have recently posted an article on this similar topic, showing a similar solution (using Transient Graphics to highlight part/segment of a polyline). But in my case, it is to highlight a segment when mouse cursor hover a polyline. I thought it may also be helpful/useful for your need.
https://drive-cad-with-code.blogspot.com/2019/02/visually-select-segment-of-polyline.html
Unfortunately, the code is also in C#. As @_gile suggested, you can find one of the online .NET code converter to easily convert the code to VB.NET.
Norman Yuan
Drive CAD With Code
