Help with switching drawings
I have done a mountain of research on how to switch drawings however it looks like its all for 2006 and better. My company is using autocad 2005 and i need to know how to get all the open documents in the current application. All the posts i have seen make reference to the DocumentCollection class, 2005 doesn't have this as far as i can find, it also says to use the Application.DocumentManager to get a collection of documents, how ever all that returns is a document manger object. I can no longer download the Arx documentation from the site and im as lost as lost can get.
The 2005 version of the API was the first, and is largely incompatible with
later releases.
For that reason, it would be in the interests of your company to upgrade if
you are planning on leveraging the managed API to any great extent.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6295328@discussion.autodesk.com...
