Hatch
Hatch
alain.holloway
Hatch
alain.holloway
I need to create a Hatch (C#) to fill this figure, all lines are Polyline.
How do I proceed?
Thank you
norman.yuan
You can learn how to write .NET API code to create a Hatch object here:
https://help.autodesk.com/view/OARX/2022/ENU/?guid=GUID-01A47A4F-9FC5-4DB6-8C3E-B72D75688965
Norman Yuan
Drive CAD With Code
alain.holloway
The problem is not with the creation of a Hatch object,  the problem is how to Append polyline with bugles (curve) without Closed property been set to true?
Thank you
alain.holloway
Setting the Polyline Closed property to true resulting in this
