Getting co-ordinates from selection set entities
I've been trying to get the co-ordinates of circles in a selection set as
created in the ObjectArx demo code. I have tried every method O can think of
but there doesn't seem to be a method of obtaining the value of the centres.
Code from the demo posted below with notes to indicate what I am trying to
do. I may be missing something obvious here as it should be a simple
process.
Thanks for any ideas.
Simon
Public Sub ssGetFilter()
'Setup
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'Declare our filter entries this way.
'We build them the same way in ObjectARX.
'DxfCode.Start (equal to 0) - This is for 'Entity Name'
'DxfCode.Color is for ACI color - 1 = Red
Dim values() As TypedValue = { _
New TypedValue(DxfCode.Start, "CIRCLE"), _
New TypedValue(DxfCode.Color, 1) _
Dim sfilter As New SelectionFilter(values) ' Create the filter using our
values...
'Set the selection options
Dim SelOpts As New PromptSelectionOptions()
SelOpts.MessageForAdding = "Select Red Circles:"
SelOpts.AllowDuplicates = True
'Make the selection:
Dim res As PromptSelectionResult = ed.GetSelection(SelOpts, sfilter)
If Not res.Status = PromptStatus.OK Then Return
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
Dim idarray As ObjectId() = SS.GetObjectIds()
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager =
db.TransactionManager
'start a transaction
Dim myT As Transaction = tm.StartTransaction()
Try
Dim id As ObjectId
For Each id In idarray
Dim entity As Entity = tm.GetObject(id, OpenMode.ForRead, True)
ed.WriteMessage((ControlChars.Lf + "You selected: " +
entity.GetType().FullName))
' ********************************************Put something here along the
lines of entity.value or id.value I can't find where the co-ords a re stored
Next id
Finally
myT.Dispose()
End Try
End Sub
If you want the center of a circle, you need to cast the object to a circle.
Thanks Frank. I have tried to do that using this code which I thought would
work but throws an error. I can get other info out such as layer, geometric
extents etc Do you know where I could get a book or some better online code
samples on this as I;m just guessing at the moment and documentation seems
pretty thin on the ground.
Cheers,
Simon
If TypeOf entity Is Autodesk.AutoCAD.DatabaseServices.Circle Then
Dim Circ As Autodesk.AutoCAD.DatabaseServices.Circle = entity
Dim k
k = Circ.Center
ed.WriteMessage((ControlChars.Lf + "CENT " & k))
End If
"Frank Oquendo" wrote in message
news:4859625@discussion.autodesk.com...
Can you post a complete example that shows the problem? This is very much
possible and in fact fairly simple to do so I'd like to look at your code to
diagnose the problem.
Albert
"Simon" wrote in message
news:4859602@discussion.autodesk.com...
process.
Simon
'Setup
values...
Try
Dim id As ObjectId
Next id
Finally
myT.Dispose()
End Try
End Sub
Albert,
Here's the code, much of it is as the sample from the sdk. I thought this
would be simple and it probably is once you know how.
Cheers,
Simon
'Setup
values...
Try
Dim id As ObjectId
'Dim entity As Entity = tm.GetObject(id, OpenMode.ForRead, True)
Dim k
k = Circ.Center
End If
Next id
Finally
myT.Dispose()
End Try
End Sub
"Albert Szilvasy" wrote in message
news:4859720@discussion.autodesk.com...
Albert
process.
Simon
'Setup
values...
Try
Dim id As ObjectId
Next id
Finally
myT.Dispose()
End Try
End Sub
The problem is simple: you are trying to cast a Point3d to a String (the
exception thrown actually says that.)
You need to modify this:
Dim k
k = Circ.Center
To this:
Dim k
k = Circ.Center
ed.WriteMessage((ControlChars.Lf + "CENT " & k.ToString()))
I could've spotted this in first post if I was a bit more versed in VB.
Albert
news:4859733@discussion.autodesk.com...
Albert,
Cheers,
Simon
'Setup
values...
Try
Dim id As ObjectId
Dim k
k = Circ.Center
End If
Next id
Finally
myT.Dispose()
End Try
End Sub
Albert
process.
Simon
'Setup
values...
Try
Dim id As ObjectId
Next id
Finally
myT.Dispose()
End Try
End Sub
Albert,
Thanks for that. I had thought to do that but .ToString doesn't come up in
intellisense so I didn't try it. If you type it in it works fine. Thanks
very much.
Simon
news:4862797@discussion.autodesk.com...
Dim k
k = Circ.Center
To this:
Dim k
k = Circ.Center
Albert
Albert,
Cheers,
Simon
'Setup
values...
Try
Dim id As ObjectId
Dim k
k = Circ.Center
End If
Next id
Finally
myT.Dispose()
End Try
End Sub
Albert
process.
Simon
'Setup
values...
Try
Dim id As ObjectId
Next id
Finally
myT.Dispose()
End Try
End Sub
