GetObject autocad application issue in autocad 2025
murugamaha
murugamaha
Hi Everybody, Good Day.
I am developing software using Visual Studio 2022 and autocad 2025. The software starts with .Net 8 COM and after autocad opens, it calls .Net 8 DLLs using sendcommand. The issue is, everytime i start the software, i have to create a new Application instead of using existing application.
   Try
       Acadapp = GetObject(, "Autocad.Application")
   Catch ex As Exception
   End Try
   Try
       Acadapp = GetObject(, "AutoCAD.Application.25")
   End Try
   Try
       Acadapp = GetObject(, "AutoCAD.Application.25.1")
   Catch ex1 As Exception
   End Try
   Try
       Acadapp = GetObject(, "AutoCAD.Application.25.0")
   End Try
   Try
       Acadapp = GetObject(, "AutoCAD.Application.25.2")
   End Try
   Acadapp = CreateObject("AutoCAD.Application")
 In the simple code, above, getobject never fetches autocad application. I tried to start without /nologo. Even then it does not work. Please help me.
ntclmain
Have a look at this link:
"The GetActiveObject method is deprecated in .NET 8, specifically starting from .NET Core 3.0. The Marshal.GetActiveObject() API is a simple wrapper over the Running Object Table (ROT) and relies on folllwing Win32 APIs that can easily be called via P/Invoke."
https://adndevblog.typepad.com/autocad/2024/07/autocad-2025-marshalgetactiveobject-net-core.html
Here are some related content you may need:
https://github.com/ReneNyffenegger/.NET-API/blob/master/System/Runtime/InteropServices/Marshal/GetAc...
https://forums.autodesk.com/t5/net/getobject-is-not-working-in-2025-beta-version/td-p/12492974
murugamaha
Thanks, I will Try. 😊
