GetObject is not working in 2025 Beta Version
serpetfree
Message 1 of 8
serpetfree
I need some help.
I've downloaded Civil 3D Vail (2025 Beta version). I've created a simple .NET 8.0 Plugin for AutoCAD 2025. (ClassLibrary)
Here my code:
     <Autodesk.AutoCAD.Runtime.CommandMethod("Testgetobject")>
     Public Sub Testgetobject()
          Dim acAppComObj As Autodesk.AutoCAD.Interop.AcadApplication
          Dim strProgId As String = "AutoCAD.Application.25"
          acAppComObj = GetObject(, strProgId)
                  If acAppComObj Is Nothing Then
                                     MsgBox("acAppComObj is Nothing")
                   else
                                      MsgBox(acAppComObj.ActiveDocument.Name)
                   End if
     End Sub
    acAppComObj is Nothing, GetObject is not working
    Can anyone help? Why is it not working?
    Thanks.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
should be placed as feedback in the beta-forum.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
ntclmain
Now AutoCAD 2025 is released, I think the topic can be opened again.
I got the same error with .Net 8, AutoCAD 2025:
     Interaction.GetObject(, "Excel.Application")
return Nothing
As describe here for .Net 8,
https://learn.microsoft.com/en-us/dotnet/api/microsoft.visualbasic.interaction.getobject?view=net-8....
Interaction.GetObject(, "Excel.Application") should return an opening Excel instance (if any). In fact, it returns Nothing in all cases.
Are there anyone got the same error?
Message 4 of 8
saviour_merlin
Community Visitor
Community Visitor
We have been using following strings in Autocad 2024 successfully.string progID = "AutoCAD.Application.24.
AcadApplication = (AcadApplication)Marshal.GetActiveObject(progID);
We have downloaded Autocad Architectural 2025 trial version. GetActiveObject is not working it is throwing an Exception.
If I use string progID = "AutoCAD.Application.25";
It throws the exception as
Unable to cast COM object of type 'System.__ComObject' to interface type 'AutoCAD.AcadApplication'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{52EE1CD2-A793-4DEC-9DF9-71CE75881F05}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).Please enable GetActiveObject string for 2025.
Message 5 of 8
_gile
Marshal.GetActiveobject is only available with .NET Framework (see the bottom of this page).
Gilles Chanteau
GileCAD
GitHub
Message 6 of 8
saviour_merlin
Community Visitor
Community Visitor
Yes u r right. While I am using my WCF Service it is not working in Autocad 2025. Still Autocad 2024 it was working fine. In Autocad 2025 it is not recognizing the string.
string progID = "AutoCAD.Application.24."
AcadApplication = (AcadApplication)Marshal.GetActiveObject(progID); It throws exception as string
not available
Message 7 of 8
daniel_cadext
Just an FYI, progID   'AutoCAD.Application.25' works from python, so its probably something wrong with .NET or your installation
def PyRxCmd_doit():
    try:
        axApp = Ax.getApp()
        print(axApp.FullName)
    except Exception as err:
        traceback.print_exception(err)
#result
#C:\Program Files\Autodesk\AutoCAD 2025\acad.exe
##wrappers
# def getApp() -> IAcadApplication:
#     id = AcadApplication.CLSID
#     return win32com.client.GetActiveObject(id)
# # This CoClass is known by the name 'AutoCAD.Application.25'
# class AcadApplication(CoClassBaseClass): # A CoClass
#     # An instance of the AutoCAD application
#     CLSID = IID('{363E5B47-885D-44C3-89EB-A2AB2129B57E}')
#     coclass_sources = [
#         _DAcadApplicationEvents,
#     default_source = _DAcadApplicationEvents
#     coclass_interfaces = [
#         IAcadApplication,
#     default_interface = IAcadApplication
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 8 of 8
_gile
It seems possible to P/Invoke GetActiveObject, see this topic.
Gilles Chanteau
GileCAD
GitHub
