Hi everybody,
at first I have to apologize, if "Nothing selected" is the wrong translation, but I'm using the German version of AutoCAD and there the message is called "Nichts gewählt."
So, here's the problem: I implented a command, that will set "inner" attributes to a user defined position. I do so by changing the property "Position" of the attribute (which actually is property "DBText.Position"). After repositioning I cannot click on the attribute again using GetNestedEntity. It just shows the text I mentioned above. I realized, that this behavior occurs, when I reposition the attribute outside of the extents of the outer block. So, it seems to me there is some "action" missing that will update the block's extents?!
I remembered playing around with the "MoveTextInBlockJig" shown at the Through the Interface blog. There, the entity (attribute/text) is moved by using the class' TransformBy() method. Is this the better way to do the repositioning? Or can I use the Position property, but with some further method to call?
Thanks!
Best regards
Max
