Add command To button
This is my button
  Dim pan1button1 As New RibbonButton()
            pan1button1.Text = "STORE"
            pan1button1.ShowText = True
            pan1button1.ShowImage = True
            pan1button1.Image = Images.getBitmap(My.Resources.Store)
            pan1button1.LargeImage = Images.getBitmap(My.Resources.Store_L)
            pan1button1.Orientation = System.Windows.Controls.Orientation.Vertical
            pan1button1.Size = RibbonItemSize.Large
            pan1button1.CommandHandler = New RibbonCommandHandler
 I have had a look online but i can seem to find how i assign the macro to the button
The macro i want to use it
"^C^C_StoreTree "
Thanks in advance
norman.yuan
Basically, you specify the CommandHandler and CommandParameter properties of a ribbon item (button, in your case):
pan1button1.CommandHandler= New MyRibbonCommandHandler()
pan1button1.CommandParameter="^C^C_StoreTree "
Then you implement ICommand interface
Public class MyRibbonCommandHandler
    Implement System.Windows.Input.ICommand
   Public Function CanExecute(...)
   End Function
   Public Event ....
   Public Sub Execute(parameter As Object) Implement....
     Dim doc As Document=Application.DocumentManager.MdiActiveDocument
     Dim riboonItem As RiboonCommandItem=TryCast(parameter, RibbonCommandItem)
     If ribbonItem IsNot Nothing Then
       doc.SendStringToExecute(ribbonItem.CommandParameter, True, False, True)
   End Sub
End class
Note the code here is just right off my head and entered through Visual Studio, not compiled, thus could have sytex error. Just meant to give you an idea how to do it.
Norman Yuan
Drive CAD With Code
I have just managed to get it sorted just before i got your message
I am using The button's ID to run the macro
(i have since added the ID to it )
and then is what i had further down
        Public Class RibbonCommandHandler
            Implements System.Windows.Input.ICommand
            Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute
                Return True
            End Function
            Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged
            Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                If TypeOf parameter Is RibbonButton Then
                    Dim button As RibbonButton = TryCast(parameter, RibbonButton)
                    doc.SendStringToExecute(button.Id & " ", True, False, False)
            End Sub
        End Class
 I have just changed this line so that it looks form the button ID and then executes it
