- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
I have a polyline in my drawing and I have to repeat a lot of times the operation to create a line and find out the intersection point with the pokyline.
RIght now, I create the line and then I erase it . entity.Erase ( )
The issue is I want to avoid this step ( create the line and then erase it) because I said, maybe my command needs to do this operation thousands of times.
So, what could I do? maybe with "drawable" objects...although I have never used them.
Thanks in advance.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
