Get location of the Edge/Face of a Solid
Basically what I have is a solid box that the user has drawn to represent a counter top. I also have a block they pull in for the sink.
All I want to do is automate the placement of the sink by letting them pick the front face of the counter top and placing the center of the sink 11" from the edge of the counter.
But I don't know how I can let them select the edge of the solid.
Can anyone help me with this?
I am interested in this solution too. Please help, thanks.
I didn't find a solution to actually picking the face of my solid. Instead I made a jig and used some geometry  to find a point on the edge of the solid.
Basically it explodes the solid , then in the jig it determins if your cursor is in front of one of the edges, then projects a point onto the edge. This may not help you, but it was good enough for me.
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Namespace TimberTools
    Namespace AcadJigs
        Class SinkToCounterJig
            Inherits EntityJig
            Private _ActualPoint As Point3d
            Private _Counter As Solid3d
            Private _Sink As BlockReference
            Private _x As TreeNode
            Private _BasePoint As Point3d
            Private _Offset As Double
            Private _BasePointOffest As Vector3d
            Private _Vector As Vector3d
            Public ReadOnly Property SelectedPoint() As Point3d
                Get
                    Return _ActualPoint
                End Get
            End Property
            Public ReadOnly Property Vector() As Vector3d
                Get
                    Return _Vector
                End Get
            End Property
            Public Sub New(ByVal BlockRef As BlockReference, ByVal Counter As Solid3d, ByVal BasePoint As Point3d, ByVal Offset As Double)
                MyBase.New(BlockRef)
                _Sink = BlockRef
                _Counter = Counter
                _BasePoint = BasePoint
                _Offset = Offset
                _BasePointOffest = _BasePoint.GetVectorTo(_Sink.Position)
                '#collect tree of expoded object. Was having trouble
                ' with acad crashes when this was all in the update routine
                _x = New TreeNode
                Dim ents As New DBObjectCollection
                '#explode wall
                _Counter.Explode(ents)
                For Each obj As DBObject In ents
                    Dim ent As New TreeNode
                    ent._Item = obj
                    If obj.GetType() Is GetType(Region) Then
                        '#Explode Region
                        Dim Lines As New DBObjectCollection
                        CType(obj, Region).Explode(Lines)
                        For Each line As DBObject In Lines
                            Dim Ln As New TreeNode
                            Ln._Item = line
                            ent._Children.Add(Ln)
                        Next
                        Lines.Clear()
                        Lines.Dispose()
                    End If
                    _x._Children.Add(ent)
                Next
                ents.Clear()
                ents.Dispose()
            End Sub
            Public Sub CleanUp()
                CleanUp(_x)
            End Sub
            Private Sub CleanUp(ByVal node As TreeNode)
                If node._Item IsNot Nothing Then
                    If GetType(DBObject).IsAssignableFrom(node._Item.GetType()) Then
                        CType(node._Item, DBObject).Dispose()
                    End If
                End If
                For Each nd As TreeNode In node._Children
                    CleanUp(nd)
                Next
            End Sub
            Protected Overloads Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
                Dim jigOpts As New JigPromptPointOptions()
                jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NoZeroResponseAccepted Or UserInputControls.NoNegativeResponseAccepted)
                jigOpts.Message = vbLf & "Pick front side of counter top: "
                jigOpts.BasePoint = _BasePoint
                jigOpts.UseBasePoint = True
                Dim dres As PromptPointResult = prompts.AcquirePoint(jigOpts)
                If _ActualPoint = dres.Value Then
                    Return SamplerStatus.NoChange
                Else
                End If
                Return SamplerStatus.OK
            End Function
            Protected Overloads Overrides Function Update() As Boolean
                Try
                    Dim NewLocation As Point3d = _Sink.Position
                    Dim Closest As Point3d = _Sink.Position
                    For Each RegNode As TreeNode In _x._Children
                        '#only look at regions (shouldn't be anything else)
                        Dim Reg As Region = RegNode._Item
                        'Exclude top and bottom regions of counter
                        If Reg.Normal.Z = 0 Then
                            '# find coordinates by examining lines
                            Dim P1 As Point3d
                            Dim P2 As Point3d
                            '# get lines of region
                            For Each lineNode As TreeNode In RegNode._Children
                                Dim line As Line = lineNode._Item
                                'Get horizontal lines
                                If line.StartPoint.Z = line.EndPoint.Z Then
                                    P1 = line.StartPoint
                                    P2 = line.EndPoint
                                End If
                            Next
                            Dim v1 As Vector3d = P1.GetVectorTo(_ActualPoint)
                            Dim v2 As Vector3d = P2.GetVectorTo(_ActualPoint)
                            Dim a1 As Double = Reg.Normal.GetAngleTo(v1)
                            Dim a2 As Double = Reg.Normal.GetAngleTo(v2)
                            Dim a3 As Double = v1.GetAngleTo(v2)
                            '< 45
                            If (a1 < 0.25 * Math.PI Or a2 < 0.25 * Math.PI) Or _
                                a3 > 0.5 * Math.PI And a1 < 0.5 * Math.PI And a2 < 0.5 * Math.PI Then
                                'Pointer in view of this region
                                Dim Loc As Point3d = _BasePoint.OrthoProject(New Plane(P1, Reg.Normal))
                                Dim Vec As Vector3d = _BasePoint.GetVectorTo(Loc).GetNormal
                                _Vector = Vec
                                Dim FinalPos As Point3d = Loc.Subtract(Vec.MultiplyBy(_Offset))
                                NewLocation = FinalPos.Add(_BasePointOffest)
                                If _ActualPoint.DistanceTo(NewLocation) < _ActualPoint.DistanceTo(Closest) Then
                                    Closest = NewLocation
                                End If
                            End If
                        End If
                    Next
                    If Closest <> _Sink.Position Then
                        _Sink.Position = Closest
                    End If
                    Return True
                Catch generatedExceptionName As System.Exception
                    Return False
                End Try
                Return True
            End Function
            Public Function GetEntity() As Entity
                Return Entity
            End Function
            Private Class TreeNode
                Public _Children As List(Of TreeNode)
                Public _Item As Object
                Sub New()
                    _Children = New List(Of TreeNode)
                End Sub
            End Class
        End Class
    End Namespace
End Namespace
