get lispended-event (vb.net)
jan_tappenbeck
jan_tappenbeck
hi !
i want to define event when lispended. the Probleme i could not found by my autocomplete.
like the object catalog is part of Document.
but look my autocomplete
could someone help ??
regards Jan
Norman_Yuan
Document.LispEnded/LispCancelled interface is exposed in Autodesk.AutoCAD.ApplicationServices.Document of accordmgd.dll. As long as you have that DLL referenced, you should have access to it.
In C#, to handle this event:
var dwg=Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiDocument;
dwg.LispEnded+=myListEndedHandler;
in VB.NET
Dim dwg = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiDocument
AddHandler dwg.ListEnded, AddressOf myLispEndedHandler
Norman Yuan
Drive CAD With Code
jan_tappenbeck
Hi !
accordmgd.dll  - are you shure ?
i did not found in map2015!
i only found accoremgd.dll !
this reference is define!
regards Jan
_gile
You have to type: AddHandler before: doc.L, so that the intellisense displays the event handlers.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
ambrosl
Here is a Help topic that demonstrates how to register and unregister the BeginDocumentClose event which is similar to how you might register the LispEnded event.
http://help.autodesk.com/view/OARX/2018/ENU/?guid=GUID-F432E285-8B94-4ACD-A186-89E1218DEC07
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
