Get instance AutoCAD with c#
In order to create a AutoCAD instance with c# is necessary this source code:
private Autodesk.AutoCAD.Interop.AcadApplicationClass _app = new Autodesk.AutoCAD.Interop.AcadApplicationClass();
Is it possible get an existing instance of AutoCAD with c#?
thanx
System.Runtime.InteropServices.Marshal.GetActiveObject()
Bobby C. Jones
http://www.acadx.com
wrote in message news:5025254@discussion.autodesk.com...
thanx
You can start acad as a process by:
Process myProcess = new Process();
myProcess.StartInfo.FileName = acadFilePath + "acad.exe";
myProcess.StartInfo.WindowStyle = myProcessssWindowStyle.Hidden;
myProcess.Start();
object obj = null;
obj = Marshal.GetActiveObject("AutoCAD.Application");
obj now points to an autocad object
or if you want to get the process:
System.Diagnostics.Process [] p = Process.GetProcessesByName("acad");
hope this helps
jbooth
This is just something on the side, but you CAN call some of those custom methods that VB programmers are so used to (in C#). You do so by using the Microsoft.VisualBasic namespace.
For example: you can get the Autocad application object by using
Microsoft.VisualBasic.Interaction.GetObject("", "AutoCAD.Application");
However. the solution posted previously is more correct, since that's what the Marshal class is for. This is just FYI.
Hello everybody,
I used something similar to run a #net code called by an icon. That mean I need to find the existing AcadProcess and not open an new Acad instance.
But I have a problem: If different instances of Acad are opened, it always find the first Acad instance. What I try to do is finding the calling Acad instance, what's the instance where click the icon.
But how to do ?
Thanks for code, help or advices,
Jean-Marc
PS: I'm under AcadMap2004.
