Get command name from autocad electrical
kebby70
kebby70
I would like to add a function to check whether AEWIRENO which a command of autocad electrical has been executed.
Commands such as copy and move can be checked for execution, but AEWIRENO is not recognized in GLOBALNAME.
please tell me how.
My code is below
public void Initialize()
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentLockModeChanged += new DocumentLockModeChangedEventHandler(vetoCommand);
private void vetoCommand(object sender, DocumentLockModeChangedEventArgs e)
if (e.GlobalCommandName == "COPY")
e.Veto();
MessageBox.Show("COPY");
if (e.GlobalCommandName == "MOVE")
e.Veto();
MessageBox.Show("MOVE");
if (e.GlobalCommandName == "AEWIRENO")
e.Veto();
MessageBox.Show("AEWIRENO");
ditran7577
Maybe it defined in group name. Try groupName or add globalName.
kebby70
kebby70
I don't know how to use, could you explain in detail?
Norman_Yuan
You can easily find out why the said command is not caught in the DocumentLockModeChanged event handler by simply place a break point in the event handler to examine the event argument, and run the said command.
If the beak point is hit, you can then examine what exactly the GlobalCommand value is; if not hit, the said command is not a "real" command, it is probably a LISP routine defined as (defun c:xxxxx....), which would not raise DocumentLockModeChanged event when it begins (but its code could raise this event along with its execution, if the lisp routine has statement like (command "xxxxx"....)...).
Norman Yuan
Drive CAD With Code
