Get block reference information error
ditran7577
Message 1 of 15
ditran7577
Hi All,
I get a block reference (has attribute) from other drawing as code follow:
Public Sub GetBlock_Info()
        Dim blockName As String = "test"
        Try
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim doclock As DocumentLock = doc.LockDocument()
            Dim ed As Editor = doc.Editor
            Dim ofd As New OpenFileDialog("Select Drawing", Nothing, "dwg; dwt", "ATS detai drawing", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
            Dim dr As System.Windows.Forms.DialogResult = ofd.ShowDialog()
            If dr <> System.Windows.Forms.DialogResult.OK Then
                Return
            End If
            Dim filePath As String = ofd.Filename
            'Using doclock
            Using OpenDb As New Database
                OpenDb.ReadDwgFile(filePath, System.IO.FileShare.ReadWrite, True, "")
                Using opentrans As Transaction = OpenDb.TransactionManager.StartTransaction()
                    Dim openBT As BlockTable = DirectCast(opentrans.GetObject(OpenDb.BlockTableId, OpenMode.ForRead), BlockTable)
                    If openBT.Has(blockName) Then
                        Dim openbtrec As BlockTableRecord = openBT(blockName).GetObject(OpenMode.ForRead)
                        Dim openbref As New BlockReference(New Point3d(0, 0, 0), openbtrec.ObjectId)
                        If openbtrec.HasAttributeDefinitions Then
                            Dim attCol As AttributeCollection = openbref.AttributeCollection
                            For Each attId As ObjectId In attCol
                                Dim attRef As AttributeReference = DirectCast(opentrans.GetObject(attId, OpenMode.ForRead), AttributeReference)
                                MsgBox(attRef.TextString)
                            Next
                        End If
                    End If
                    opentrans.Commit()
                    opentrans.Dispose()
                End Using
            End Using
       Catch ex As Autodesk.AutoCAD.Runtime.Exception
        End Try
    End Sub
Block "test" contains some attributes but the code can not get them.
Hope for help.
Replies (14)
Message 2 of 15
Alexander.Rivilis
@ditran7577 wrote:
...Block "test" contains some attributes but the code can not get them...
That is why you do not add attributes after inserting of block: Inserting a block with attributes to modelspace
You have to iterate block definition to find all non-constant AttributeDefinitions and adding corresponding AttributeReferences to openbref.AttributeCollection
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 15
ditran7577
I have just get information from attribute of that block. I do not want to add it into model space. How to?
Message 4 of 15
Alexander.Rivilis
I think you do not understand me. Reread my post and my link again.
Expert Elite Member
Message 5 of 15
ditran7577
Was it an impossibility?
Message 6 of 15
Alexander.Rivilis
If you create BlockReference with code and do not add AttributeReferences to BlockReference.AttributeCollection - then there are no AttributeReference within BlockReference. So in this case you can only get AttributeDefinitions from BlockTableRecord.
Expert Elite Member
Message 7 of 15
ditran7577
But I want to read the block only. I don't creat or insert it.
Message 8 of 15
Alexander.Rivilis
Repeat:
Expert Elite Member
Message 9 of 15
Are there any way to get value of AttributeDefinitions. Thanks.
Message 10 of 15
Alexander.Rivilis
Of course!
      Dim DB As Database = HostApplicationServices.WorkingDatabase
      Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
      Dim trans As Transaction = DB.TransactionManager.StartTransaction
      Using trans
        Dim id As ObjectId ' id of our BlockTableRecord - in your's case is openBT(blockName)
        Dim btAttRec As BlockTableRecord = trans.GetObject(id, OpenMode.ForRead)
        Dim idAtt As ObjectId
        For Each idAtt In btAttRec
          Dim ent As Entity = trans.GetObject(idAtt, OpenMode.ForRead)
          If TypeOf ent Is AttributeDefinition Then
            Dim attDef As AttributeDefinition = CType(ent, AttributeDefinition)
            ed.WriteMessage(vbCrLf + "attdef.TextString = {0}", attDef.TextString)
            ed.WriteMessage(vbCrLf + "attdef.Tag = {0}", attDef.Tag)
          End If
        Next
        trans.Commit()
      End Using
Expert Elite Member
Message 11 of 15
AttDef.textstring ="" although AttributeDefinition has value. What happen?
Message 12 of 15
Alexander.Rivilis
I do not know what happen. Maybe you again confused AttributeDefinition in BlockTableRecord and AttributeReference in inserted BlockReference.
Please attach dwg-file with block and explain what do you mean.
Expert Elite Member
Message 13 of 15
 <CommandMethod("test")> _
    Public Sub test()
        Dim blockName As String = "blank_sheet"
        Dim ofd As New OpenFileDialog("CAD FILE", Nothing, "dwg; dwt", "CAD FILE", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
            Return
        End If
        Dim sourcefile As String = ofd.Filename
        Dim acCurDb As Database = doc.Database
        Using doclock
            Using OpenDb As New Database(False, True)
                OpenDb.ReadDwgFile(sourcefile, System.IO.FileShare.ReadWrite, True, "")
                        Dim id As ObjectId = openBT(blockName)
                        Dim btAttRec As BlockTableRecord = opentrans.GetObject(id, OpenMode.ForRead)
                            Dim ent As Entity = opentrans.GetObject(idAtt, OpenMode.ForRead)
                            End If
                        Next
                    Else
                        opentrans.Commit()
                        Exit Sub
                    End If
                    opentrans.Commit()
                End Using
            End Using
        End Using
    End Sub
Thanks.
Message 14 of 15
Alexander.Rivilis
I was right and you confuse BlockTableRecord and BlockReference, AttributeDefinition and AttributeReference.
Try this code (no error checking done):
Public Sub test()
  Dim ofd As New Autodesk.AutoCAD.Windows.OpenFileDialog( _
   "CAD FILE", Nothing, "dwg; dwt", "CAD FILE", _
    Return
  End If
  Dim doc As Document = _
   Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument()
  Using doclock
        Dim openBT As BlockTable = _
          For Each idBref As ObjectId In btAttRec.GetBlockReferenceIds(True, True)
            Dim bRef As BlockReference = opentrans.GetObject(idBref, OpenMode.ForRead)
            For Each idAttRef In bRef.AttributeCollection
              Dim attRef As AttributeReference = opentrans.GetObject(idAttRef, OpenMode.ForRead)
              ed.WriteMessage(vbCrLf + "attRef.Tag = {0}", attRef.Tag)
              ed.WriteMessage(vbCrLf + "attRef.TextString = {0}", attRef.TextString)
            Next
          Next
        End If
        opentrans.Commit()
      End Using
    End Using
  End Using
End Sub
Expert Elite Member
Message 15 of 15
Oh. Thanks so much.
