Get attribute from a block
I need to open a drawing and read the block attributes and find a block with name "ABC" and attribute named "Text" in "ABC" block. for which i am using the below code which is working perfectly.
Try
            AcadApp = GetObject(, "AutoCAD.Application")
        Catch ex As Exception
            AcadApp = CreateObject("AutoCAD.Application")
        End Try
        AcadApp.Visible = True
        Try
            AcadDoc = AcadApp.Documents.Open(DWGName, True)
            RichTextBox1.AppendText("   -   Opened File Successfully" & vbCrLf)
            Me.Refresh()
            RichTextBox1.AppendText("   -   Can not Open this Drawing" & vbCrLf)
            Me.Refresh()
            Exit Function
        End Try
        Dim Obj As Object
        For Each Obj In AcadDoc.ModelSpace
            If Obj.ObjectName = "AcDbBlockReference" Then
                RibbonLabel1.Text = "Find Block: " & Obj.Name
                Me.Refresh()
                ' Check for attributes.
                If Obj.HasAttributes Then
                    Dim AttList As Object
                    Me.Refresh()
                    If Obj.Name.ToString.ToLower = "abc" Then
                        ' Build a list of attributes for the current block.
                        AttList = Obj.GetAttributes
                        ' Cycle throught the list of attributes.
                        For _i = LBound(AttList) To UBound(AttList)
                            ' Check for the correct attribute tag.
                            If AttList(_i).TagString = "Text" Then
                                return AttList(_i).TextString.ToString
                                End If
                                Me.Refresh()
                            End If
                        Next
                    End If
                End If
            End If
        Next Obj
 But i want to know whether is there any way to get the block named "ABC" directly without looping through all the objects.
Thank you.
Alfred.NESWADBA
Yes, there are two possibilities if you work managed (DLL in AutoCAD) or of you work COM-based (because you control AutoCAD from an external EXE):
Managed:
Get the BlockTableRecord for Block "ABC"
then you have access to the function GetBlockReferenceIDs ==> that gives you the ObjectID's of all references of this block-definition
COM + SelectionSet
Create a SelectionSet with a filter
(0 . INSERT) to define it searches for a BlockReference
(2 . "ABC") to have the BlockName defined you look for
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Hallex
{code}
Try this 5-mintes solution
(Win7 A2009 .NETRFramework 3.5)
Public Class Form1
    Dim DWGName As String = "C:\Test\WorkingDrawing.dwg"
    Dim AcadApp
    Dim AcadDoc
    Dim oSsets
    Dim oSset
    Dim ftype(0 To 3) As Short
    Dim fdata(0 To 3) As Object
    Public Function DoYourWork() As Boolean
        Dim bln As Boolean = False
        Try
        End Try
        Try
            Me.Refresh()
            Me.Refresh()
            bln = False
            Return bln
            Exit Function
        End Try
        Dim pfset As Object
        pfset = AcadDoc.PickFirstSelectionSet
        pfset.Clear()
        ftype(0) = 0 : ftype(1) = 2 : ftype(2) = 66 : ftype(3) = 410
        fdata(0) = "insert" : fdata(1) = "abc" : fdata(2) = 1 : fdata(3) = "Model"
        Call pfset.Select(5, Nothing, Nothing, ftype, fdata)'<--5= acSelectionSetAll
        MsgBox("Selected: " & pfset.Count.ToString)
        Dim Obj As Object
        Dim msg As String = ""
        For Each Obj In pfset
                Me.Refresh()
                    Me.Refresh()
                        AttList = Obj.GetAttributes ' Cycle throught the list of attributes.
                            '' Check for the correct attribute tag.
                                Return AttList(_i).TextString.ToString
                                Me.Refresh()
                            End If
                        Next
                    End If
                End If
            End If
        Next Obj
        Return True
    End Function
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        DoYourWork()
    End Sub
End Class
{/code}
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
