Get angle in Z axis
Get angle in Z axis
waseefur.rahman
Get angle in Z axis
waseefur.rahman
Hi Everyone!
I am trying to get the angle between two lines, I have attached the image
For getting the angle in Z axis I have changed the ucs and then I tried to get the angle, but It has been showing the angle in xy, only ucs has been changed to specified point.
Dim Vuline As Line = New Line(center, ptver)
               '' Add the line to the drawing
                curSpace.AppendEntity(Vuline)
                tr.AddNewlyCreatedDBObject(Vuline, True)
                Dim Vlline As Line = New Line(center, ptlow)
                curSpace.AppendEntity(Vlline)
                tr.AddNewlyCreatedDBObject(Vlline, True)
 Dim vlPt1 As Point3d = Vlline.StartPoint
Dim vlPt2 As Point3d = Vlline.EndPoint
 Dim vuPt1 As Point3d = Vlline.StartPoint
Dim vuPt2 As Point3d = Vlline.EndPoint
'change use
                Dim acUCSTbl As UcsTable
                acUCSTbl = tr.GetObject(acCurDb.UcsTableId, OpenMode.ForRead)
                Dim acUCSTblRec As UcsTableRecord
                ' Check to see if the "Window_UCS" UCS table record exists
                If acUCSTbl.Has("New_UCS") = False Then
                    acUCSTblRec = New UcsTableRecord()
                    acUCSTblRec.Name = "New_UCS"
                    '' Open the UCSTable for write
                    acUCSTbl.UpgradeOpen()
                    '' Add the new UCS table record
                    acUCSTbl.Add(acUCSTblRec)
                    tr.AddNewlyCreatedDBObject(acUCSTblRec, True)
                Else
                    acUCSTblRec = tr.GetObject(acUCSTbl("New_UCS"), OpenMode.ForWrite)
                End If
                Dim StartPts = center
                Dim EndPts = New Point3d(ptver.X, ptver.Y, center.Z)
                Dim AnglePts = ptver
                Dim xVex As Vector3d
                Dim yVex As Vector3d
                Dim zVex As Vector3d
                Dim AngleCord As Matrix3d
                xVex = center.GetVectorTo(EndPts).GetNormal()
                zVex = xVex.CrossProduct(StartPts.GetVectorTo(AnglePts)).GetNormal()
                yVex = zVex.CrossProduct(xVex).GetNormal()
                AngleCord = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, StartPts, xVex, yVex, zVex)
                acUCSTblRec.Origin = AngleCord.CoordinateSystem3d.Origin
                acUCSTblRec.XAxis = AngleCord.CoordinateSystem3d.Xaxis
                acUCSTblRec.YAxis = AngleCord.CoordinateSystem3d.Yaxis
                '' Open the active viewport
                Dim acVportTblRec As ViewportTableRecord
                acVportTblRec = tr.GetObject(acDoc.Editor.ActiveViewportId,
                                          OpenMode.ForWrite)
                '' Display the UCS Icon at the origin of the current viewport
                acVportTblRec.IconAtOrigin = True
                acVportTblRec.IconEnabled = True
                '' Set the UCS current
                acVportTblRec.SetUcs(acUCSTblRec.ObjectId)
                acDoc.Editor.UpdateTiledViewportsFromDatabase()
Dim acLinAngDimv As LineAngularDimension2 = New LineAngularDimension2()
acLinAngDimv.XLine1Start = New Point3d(vlPt1.X, vlPt1.Y, 0)
                acLinAngDimv.XLine1End = New Point3d(vlPt2.X, vlPt2.Y, 0)
                acLinAngDimv.XLine2Start = New Point3d(vuPt1.X, vuPt1.Y, 0)
                acLinAngDimv.XLine2End = New Point3d(vuPt2.X, vuPt2.Y, 0)
                'acLinAngDims.ArcPoint = New Point3d(3, 5, 0)
                acLinAngDimv.DimensionStyle = acCurDb.Dimstyle
                '' Add the new object to Model space and the transaction
                curSpace.AppendEntity(acLinAngDimv)
                tr.AddNewlyCreatedDBObject(acLinAngDimv, True)
could anyone guide me, how to changed the code to achieve the result..
ActivistInvestor
@waseefur.rahman wrote:
Hi Everyone!
I'm not sure I understand what 'the angle in Z axis' means. Do you mean the angle in the XZ or YZ plane?
In any case, the angle between any two lines in 3D space in the plane that both lines lie in:
Line line1 = ....
Line line2 = ....
Vector3d v1 = line1.StartPoint.GetVectorTo(line1.EndPoint); Vector3d v2 = line2.StartPoint.GetVectorTo(line2.EndPoint);
double angle = v1.GetAngleTo(v2);
To get the angle of a line in the XZ plane, from the X axis:
Line line = ... (lies in the XZ plane)
Vector3d vector = line.StartPoint.GetVectorTo(Line.EndPoint);
double angle = Vector3d.XAxis.GetAngleTo(vector);
;; or where the line is in the YZ plane:
double angle = Vector3d.YAxis.GetAngleTo(vector);
To get the angle of a line in any plane that's parallel to the Z axis, you can use the same method as the above, to find the angle between the line and the Z axis (Vector3d.ZAxis), and the difference between that and 90 degrees is the angle of the line (e.g., the 'slope') from the XY plane.
