From Handle to Object
Hi All,
I saved a object handle in listview item tag
lvItem.tag=objFixture.Handle.ToString
 later on I pass this handle to another function
    Private Sub func(ByVal strHandle As String, ByVal strError As String)
        Dim ed As Editor = acApp.DocumentManager.MdiActiveDocument.Editor
        Dim trans As Transaction = acApp.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction
        Dim db As Database = acApp.DocumentManager.MdiActiveDocument.Database
        Try
            Dim objID As ObjectId = db.GetObjectId(False, New Handle(Convert.ToInt64(strHandle, 16)), 0)
            Dim objFixture As BlockReference = trans.GetObject(objID, OpenMode.ForWrite)  ' Here will throw error
            Dim rbOld As ResultBuffer = objFixture.GetXDataForApplication(STR_XDATA_FIXTURE)
            Dim tvOld() As TypedValue = rbOld.AsArray
            Dim rbNew As New ResultBuffer(tvOld)
            objFixture.XData = rbNew
            rbNew.Dispose()
            trans.Commit()
        Catch ex As Exception
            ' strError = ex.Message.ToString
            trans.Abort()
        Finally
            trans.Dispose()
        End Try
    End Sub
Calling part is
Func(lvItem.Tag.ToString, strError)
Basically I would like to get a blockreference based on the handle then get/set its xdata
Any ideas?
This question may obvious to you guys, as I am new to .Net AutoCAD
Instead of using Convert(), use Int64.Parse() and specify the allowhex option.
I have changed to
Dim objID As ObjectId = db.GetObjectId(False, New Handle(Int64.Parse(strHandle, Globalization.NumberStyles.AllowHexSpecifier)), 0)
but still can not create object.
In my catch
ex.message.tostring is
"eLockViolation"
Any idea?
I found the problem
If I try to getObject for Read it works fine, but if for write it doesn't work.
How can that happen?
"eLockViolation"
thanks
You must use the Document's LockDocument() method to lock the
document before you can open objects for write.
In C# the basic usage is:
   using( DocumentLock mylock = myDocument.LockDocument() )
        // here you modify the database.
