Formating a table AutoCad .NET C#
malmal02122023
malmal02122023
Could you help me please?
Is it possible to format a table that is already prepared? Select the table and change the row height and text height and font style. Thank you.
Best regards
Olek
Domzinator
malmal02122023
Thank you for an advice.
Using the examples I was able to write the code as shown below but when running a command in AutoCad 2022 it gives me this error (see attachment).
I'm trying to format the table so that it only has header and data rows only with rows height 6.8 and text height 3.5.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
using System.Collections.Generic;
using Excel = Microsoft.Office.Interop.Excel;
using Autodesk.AutoCAD.Colors;
namespace LinkToExcel
    public class Commands
        [CommandMethod("S2T")]
        static public void UpdateTableFromSpreadsheet()
            var doc =
              Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var opt = new PromptEntityOptions("\nSelect table to update");
            opt.SetRejectMessage("\nEntity is not a table.");
            opt.AddAllowedClass(typeof(Table), false);
            var per = ed.GetEntity(opt);
            if (per.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                try
                    var obj = tr.GetObject(per.ObjectId, OpenMode.ForRead);
                    var tb = obj as Table;
                    // It should always be a table
                    // but we'll check, just in case
                    if (tb != null)
                        // The table must be open for write
                        tb.UpgradeOpen();
                        // Update data link from the spreadsheet
                        var dlIds = tb.Cells.GetDataLink();
                        foreach (ObjectId dlId in dlIds)
                            var dl =
                              (DataLink)tr.GetObject(dlId, OpenMode.ForWrite);
                            dl.Update(
                              UpdateDirection.SourceToData,
                              UpdateOption.None
                            // And the table from the data link
                            tb.UpdateDataLink(
                              UpdateOption.None
                    tr.Commit();
                    ed.WriteMessage(
                      "\nUpdated the table from the spreadsheet."
                catch (Exception ex)
                    ed.WriteMessage(
                      "\nException: {0}",
                      ex.Message
        [CommandMethod("T2S")]
        static public void UpdateSpreadsheetFromTable()
            var doc =
            var opt =
                "\nSelect table with spreadsheet to update"
                return;
            Transaction tr =
              db.TransactionManager.StartTransaction();
            using (tr)
                try
                    DBObject obj =
                    Table tb = obj as Table;
                    if (tb != null)
                        tb.UpgradeOpen();
                        // Update the data link from the table
                        tb.UpdateDataLink(
                          UpdateDirection.DataToSource,
                          UpdateOption.ForceFullSourceUpdate
                        // And the spreadsheet from the data link
                            var dl =
                            dl.Update(
                    tr.Commit();
                    ed.WriteMessage(
                      "\nUpdated the spreadsheet from the table."
                    ed.WriteMessage("\nException: {0}", ex.Message);
        static public List<string> GetSheetNames(string excelFileName)
            var listSheets = new List<string>();
            var excel = new Excel.Application();
            var wbs = excel.Workbooks.Open(excelFileName);
            foreach (Excel.Worksheet sheet in wbs.Worksheets)
                listSheets.Add(sheet.Name);
            excel.Quit();
            return listSheets;
        [CommandMethod("WELDTABLE")]
        static public void TableFromSpreadsheet()
            const string dlName = "Import table from Excel demo";
            var doc =
            // Ask the user to select an XLS(X) file
            var ofd =
              new OpenFileDialog(
                "Select Excel spreadsheet to link",
                null,
                "xls; xlsx",
                "ExcelFileToLink",
                OpenFileDialog.OpenFileDialogFlags.
                  DoNotTransferRemoteFiles
            var dr = ofd.ShowDialog();
            if (dr != System.Windows.Forms.DialogResult.OK)
                return;
            // Display the name of the file and the contained sheets
            ed.WriteMessage(
              "\nFile selected was \"{0}\". Contains these sheets:",
              ofd.Filename
            // First we get the sheet names
            var sheetNames = GetSheetNames(ofd.Filename);
            if (sheetNames.Count == 0)
                ed.WriteMessage(
                  "\nWorkbook doesn't contain any sheets."
                return;
            // And loop through, printing their names
            for (int i = 0; i < sheetNames.Count; i++)
                var name = sheetNames[i];
                ed.WriteMessage("\n{0} - {1}", i + 1, name);
            // Ask the user to select one
            var pio = new PromptIntegerOptions("\nSelect a sheet");
            pio.AllowNegative = false;
            pio.AllowZero = false;
            pio.DefaultValue = 1;
            pio.UseDefaultValue = true;
            pio.LowerLimit = 1;
            pio.UpperLimit = sheetNames.Count;
            var pir = ed.GetInteger(pio);
            if (pir.Status != PromptStatus.OK)
                return;
            // Ask for the insertion point of the table
            var ppr = ed.GetPoint("\nEnter table insertion point");
            if (ppr.Status != PromptStatus.OK)
                return;
            // Remove any Data Link, if one exists already
            var dlm = db.DataLinkManager;
            var dlId = dlm.GetDataLink(dlName);
            if (dlId != ObjectId.Null)
                dlm.RemoveDataLink(dlId);
            // Create and add the new Data Link, this time with
            // a direction connection to the selected sheet
            var dl = new DataLink();
            dl.DataAdapterId = "AcExcel";
            dl.Name = dlName;
            dl.Description = "Excel fun with Through the Interface";
            dl.ConnectionString =
              ofd.Filename + "!" + sheetNames[pir.Value - 1];
            dl.DataLinkOption =
              DataLinkOption.PersistCache;
            dl.UpdateOption |=
              (int)UpdateOption.AllowSourceUpdate;
            dlId = dlm.AddDataLink(dl);
            using (var tr = doc.TransactionManager.StartTransaction())
                    const string styleName = "weld table style";
                    ObjectId tsId = ObjectId.Null;
                    DBDictionary sd =
                        (DBDictionary)tr.GetObject(
                            db.TableStyleDictionaryId,
                            OpenMode.ForRead
                    if (sd.Contains(styleName))
                        tsId = sd.GetAt(styleName);
                    else
                        TableStyle ts = new TableStyle();
                        ts.SetTextHeight(3.5, (int)RowType.HeaderRow);
                        ts.SetTextHeight(3.5, (int)RowType.DataRow);
                        ts.HorizontalCellMargin = 0.5;
                        ts.VerticalCellMargin = 0.2;
                        ts.SetColor(
                        Color.FromColorIndex(ColorMethod.ByAci, 2),
                         (int)(RowType.HeaderRow));
                        ts.SetColor(
                         (int)(RowType.DataRow));
                        ts.SetGridColor(
                         (int)GridLineType.AllGridLines,
                        ts.SetGridColor(
                         Color.FromColorIndex(ColorMethod.ByAci, 1),
                        tsId = ts.PostTableStyleToDatabase(db, styleName);
                        tr.AddNewlyCreatedDBObject(ts, true);
                    var bt =
                      (BlockTable)tr.GetObject(
                        db.BlockTableId,
                        OpenMode.ForRead
                // Create our table
                var tb = new Table();
                tb.Position = ppr.Value;
                tb.Cells.SetDataLink(dlId, true);
                tb.GenerateLayout();
                if (tsId == ObjectId.Null)
                    tb.TableStyle = db.Tablestyle;
                else
                    tb.TableStyle = tsId;
                // Add it to the drawing
                var btr =
                  (BlockTableRecord)tr.GetObject(
                    db.CurrentSpaceId,
                    OpenMode.ForWrite
                tb.SetColumnWidth(0, 16.5);
                tb.SetColumnWidth(1, 14.7);
                tb.SetColumnWidth(2, 18.3);
                tb.SetColumnWidth(3, 14.7);
                tb.SetColumnWidth(4, 18.3);
                tb.SetColumnWidth(5, 24.3);
                tb.SetColumnWidth(6, 28.5);
                tb.SetColumnWidth(7, 14.7);
                tb.SetColumnWidth(8, 28.5);
                tb.SetColumnWidth(9, 14.7);
                tb.SetColumnWidth(10, 17.7);
                tb.SetColumnWidth(11, 25.5);
                btr.AppendEntity(tb);
                tr.AddNewlyCreatedDBObject(tb, true);
                tr.Commit();
