First line program
First line program
pedcarson
Message 1 of 10
First line program
pedcarson
Hi everyone,
I'm trying to create a basic program using the code given on the AutoCAD developers guide.
I've created a class and then called the class with a button in a c# windows form. The code is for the class is below. The line "Document acDoc = Application.DocumentManager.MdiActiveDocument;" causes the program to stop? Any ideas? The button calls class DrawLine.AddLine
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace AutoCAD_Line_Test
     class DrawLine
        [CommandMethod("AddLine")]
        public static void AddLine()
            // Get the current document and database
            Database acCurDb = acDoc.Database;
            // Start a transaction
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                // Open the Block table for read
                BlockTable acBlkTbl;
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                             OpenMode.ForRead) as BlockTable;
                // Open the Block table record Model space for write
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                                OpenMode.ForWrite) as BlockTableRecord;
                // Create a line that starts at 5,5 and ends at 12,3
                Line acLine = new Line(new Point3d(5, 5, 0),
                                       new Point3d(12, 3, 0));
                acLine.SetDatabaseDefaults();
                // Add the new object to the block table record and the transaction
                acBlkTblRec.AppendEntity(acLine);
                acTrans.AddNewlyCreatedDBObject(acLine, true);
                // Save the new object to the database
                acTrans.Commit();
Replies (9)
Message 2 of 10
norman.yuan
Well, since you know the code stops at the first line, all lines of the code after that are irrelevant, and the relevant code that might be the real cause of the issue is the caller: the windows form, which you did not show, nor describe how/where it runs.
Is this win form in another DLL file that also runs as AutoCAD Add-in (NETLOADED into AutoCAD)? or it is part of stand-alone app (EXE)? If it is later, then from the EXE, you CANNOT use DLLs built with AutoCAD .NET API.
Describe what kind of project you are doing, and from where the win form runs.
Norman Yuan
Drive CAD With Code
Message 3 of 10
_gile
The AutoCAD .NET API is designed to run in-process only.
If your project is a standalone executable (e.g. a Windows Form based project) you cannot directly use the AutoCAD .NET API.
See this topic in the Developer's Guide.
If you want to create an AutoCAD custom command as your example, you have to build a DLL (starting from a Class Library template) and load it in AutoCAD (the class containing the command have to be public).
See this section in the Developer's Guide.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 4 of 10
pedcarson
I wasn't aware of netloading. I assumed I could run an exe. My aim is to
have a windows form program with different values to fit in which would
then draw certain shapes, eventually import a block and then scale it etc.
All from a couple of inputs from the user.
This is obviously my first program I'm writing in c# for autocad. I don't
see much in tutorials for c# on the internet.
Message 5 of 10
norman.yuan
Since you seems emphasizing C#, and not aware of "NETLOAD":
Using C#, or other .NET language (VB.NET, F#...) does not matter here. What matters is which AutoCAD API to use: if you use AutoCAD .NET API, as your code showed in your original post, you CANNOT use them in EXE application, you would need redesign/restructure of your solution: app runs inside AutoCAD (as DLL), or app run outside AutoCAD (exe, which in turn automate AutoCAD in someway), based on the APIs you use (.NET API, or COM API, or both mixed).
Norman Yuan
Drive CAD With Code
Message 6 of 10
BKSpurgeon
Hi OP
my estimable colleagues @_gile and @norman.yuan have said it all and anything they write is very good. but i'm not sure if you understand what they are saying given your comments. so i thought to simplify it:
in process
this means that the user has to first open autocad. i.e. double click on the AutoCAD icon and start up autocad. once autocad is open and a drawing is opened, then the user has to type in a command: "NETLOAD" and has to select the a file - the result of all your programming/coding efforts. once that file is selected the user then has to run the command "AddLine". the command will run as you have coded it. in order to do it this way you will need the .Autocad net API
out of process
In this case, you don't necessarily have to manually open AutoCAD up. you create your own program, and you open it (much like you would open MS word etc) and your "AddLine" command would run without you, as a user, manually opening autocad and netloadin etc.. if you're going down this path you need to use the COM interop API.
using both
if you really want to use the .net API, but did not want to manually netload, then you can use a combination of both of the above:
From the documentation:
If you need to create a stand-alone application to drive AutoCAD, it is best to create an application that uses the CreateObject and GetObject methods to create a new instance of an AutoCAD application or return one of the instances that is currently running. Once a reference to an AcadApplication is returned, you can then load your in-process .NET application into AutoCAD by using the SendCommand method that is a member of the ActiveDocument property of the AcadApplication.
> As an alternative to executing your .NET application in-process, could use COM interop for your application.
hope this clears it  up.
Message 7 of 10
pedcarson
Thanks for such a detailed response. I would prefer to use an external
program but I think the main objective is to have variables at the
beginning that are defined by the user. So instead of just typing add line
and having x and y coordinates, I could have x and y set to variables that
are set at the start through a form. Then when addline is executed, the
line changes according to the variables.
Similarly I was hoping to have a block inserted and scaled. I'd rather get
away from typing commands and have a user interface that anyone could use?
Message 8 of 10
_gile
If you want to use a standalone Windows Form executable, you have to keep mind you have to use the COM API which is less powerfull than the .NET one and which have compatibility issues with platform (32 or 64 bits) and with AutoCAD major versions.
Here's a trivial example using a very simple Windows Form:
The Form Class code (Autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common libraries corresponding to targetted version of AutoCAD have to be referenced).
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using System;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace WinFormStandAlone
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            btnOK.Click += BtnOK_Click;
        private void BtnOK_Click(object sender, EventArgs e)
            double[] startPoint, endPoint;
            if (!TryParseToPoint(txtStartPoint.Text, out startPoint))
                MessageBox.Show($"Invalid Start point.");
            if (!TryParseToPoint(txtEndPoint.Text, out endPoint))
                MessageBox.Show($"Invalid End point.");
            AcadApplication acadApp;
            string progId = "AutoCAD.Application.19";
            try
                acadApp = (AcadApplication)Marshal.GetActiveObject(progId);
            catch
                try
                    acadApp = (AcadApplication)Activator.CreateInstance(Type.GetTypeFromProgID(progId), true);
                catch
                    MessageBox.Show("Instance of 'AutoCAD.Application' could not be created.");
                    return;
            while (true)
                try { acadApp.Visible = true; break; }
                catch { }
            acadApp.WindowState = AcWindowState.acMax;
            AcadDocument doc = acadApp.ActiveDocument;
            AcadModelSpace modelSpace = doc.ModelSpace;
            modelSpace.AddLine(startPoint, endPoint);
        private static bool TryParseToPoint(string source, out double[] point)
            point = null;
            string[] array = source.Split(',');
            if (array.Length < 2 || array.Length > 3)
                return false;
            double x, y, z = 0.0;
            if (!double.TryParse(array[0], out x))
                return false;
            if (!double.TryParse(array[1], out y))
                return false;
            if (array.Length == 3 && !double.TryParse(array[2], out z))
                return false;
            point = new[] { x, y, z };
            return true;
Using the AutoCAD .NET API, you can also have a user interface as modal dialog (the dialog form have the same controls as upper):
namespace InProcessDialog
    public partial class Dialog : Form
        public string StartPoint => txtStartPoint.Text;
        public string EndPoint => txtEndPoint.Text;
        public Dialog()
            btnOK.DialogResult = DialogResult.OK;
The dialog is opened from AutoCAD with the "DRAWLINEDLG" command:
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
    public class Commands
        [CommandMethod("DrawLineDlg")]
        public void DrawLine()
            var dlg = new Dialog();
            if (AcAp.ShowModalDialog(dlg) == DialogResult.OK)
                Point3d startPoint, endPoint;
                if (!TryParseToPoint(dlg.StartPoint, out startPoint))
                    return;
                if (!TryParseToPoint(dlg.EndPoint, out endPoint))
                    return;
                var doc = AcAp.DocumentManager.MdiActiveDocument;
                var db = doc.Database;
                var ed = doc.Editor;
                using (var tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                    Line line = new Line(startPoint, endPoint);
                    modelSpace.AppendEntity(line);
                    tr.AddNewlyCreatedDBObject(line, true);
                    tr.Commit();
        private static bool TryParseToPoint(string source, out Point3d point)
            point = default(Point3d);
                return false;
                return false;
                return false;
                return false;
            point = new Point3d(x, y, z);
            return true;
You can also use a modeless user interface from AutoCAD (typically a palette set)
The user control (a palette tab of the palette set) contains the same controls as the upper forms.
With modeless user interfaces, it's simpler and safer to call cusom commands from event handlersso that AutoCAD takes care of locking the document and setting the focus to AutoCAD window.
using System;
namespace InProcessPalette
    public partial class DrawLineTab : UserControl
        public DrawLineTab()
        private void btnOK_Click(object sender, EventArgs e)
            if (!IsValidPoint(txtStartPoint.Text))
                MessageBox.Show("Invalid Start Point.");
                return;
            if (!IsValidPoint(txtEndPoint.Text))
                MessageBox.Show("Invalid End Point.");
                return;
            doc?.SendStringToExecute($"DrawLineCmd {txtStartPoint.Text} {txtEndPoint.Text} ", false, false, false);
        private bool IsValidPoint(string source)
                return false;
            double x;
                return false;
            if (!double.TryParse(array[1], out x))
                return false;
            if (array.Length == 3 && !double.TryParse(array[2], out x))
                return false;
            return true;
The palette is showned by running the "CMD_PALETTE" command, and a click on the OK button launches the "DrawLineCmd" which can also be directly called.
using System;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Windows;
        static PaletteSet palette;
        static bool wasVisible;
        [CommandMethod("CMD_PALETTE")]
        public void CmdPalette()
            if (palette == null)
                palette = new PaletteSet(
                    "Palette",
                    "CMD_PALETTE",
                    new Guid("{4E63230E-EEB0-45FF-A9A1-65D4FDEAE5DC}"));
                palette.Style =
                    PaletteSetStyles.ShowAutoHideButton |
                    PaletteSetStyles.ShowCloseButton |
                    PaletteSetStyles.ShowPropertiesMenu;
                palette.MinimumSize = new System.Drawing.Size(250, 150);
                palette.Add("Draw Line", new DrawLineTab());
                var docs = AcAp.DocumentManager;
                docs.DocumentBecameCurrent += (s, e) =>
                    palette.Visible = e.Document == null ? false : wasVisible;
                docs.DocumentCreated += (s, e) =>
                    palette.Visible = wasVisible;
                docs.DocumentToBeDeactivated += (s, e) =>
                    wasVisible = palette.Visible;
                docs.DocumentToBeDestroyed += (s, e) =>
                    if (docs.Count == 1)
                        palette.Visible = false;
            palette.Visible = true;
        [CommandMethod("DrawLineCmd")]
            var doc = Application.DocumentManager.MdiActiveDocument;
            var options = new PromptPointOptions("\nStart Point: ");
            var result = ed.GetPoint(options);
            if (result.Status != PromptStatus.OK)
                return;
            var startPoint = result.Value;
            options.BasePoint = startPoint;
            options.UseBasePoint = true;
            options.Message = "\nend Point: ";
                return;
            var ucs = ed.CurrentUserCoordinateSystem;
            var endPoint = result.Value.TransformBy(ucs);
            startPoint = startPoint.TransformBy(ucs);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 9 of 10
BKSpurgeon
As @_gile has kindly noted in his post - and also very kindly provided sample code too: you can certainly have forms in your plugin - if you're doing that then I recommend you do things in process -  use the powerful .net API. just type in "AddLine" and the form will come up. Refer to Gilles' post.
Message 10 of 10
pedcarson
Thank you for the detailed response, this will certainly help with understanding how to put all this together!
