Finding & Replacing Mtext in a Block using VB.net?
Message 1 of 32
Hi everyone,
I've been trying to find help on replacing Mtext in a drawing border of mine. The drawing border is a block that has constant attributes that I have a vb.net dll that can edit the constant attributes.
I'm trying to add this to that dll, I would like this to work in such a way as to not have the user involved. My thought was to have the code executed when the form was loaded to edit the values in the titleblock. The code would look to see if the Mtext existed in the border and if so replace it with the correct Mtext. If the correct Mtext is there it would exit the Sub.
I'm have a hard time figuring out how to use the Transaction concept. I've tried to modify an exisitng function in the VB.net dll to do this change.
As you can see in this example code, I'm not very good at figuring out how to modify it to my needs. I'm still not sure how some of these "BIG PICTURE" concepts work?
Do I need one function to read and another function to write? Do I need a Sub to strat to function(s)?  I understand most of  form code.
Any pointers in the correct direction would be appreciated....
PublicSharedFunction ReadMtextFromBTR(ByVal strName AsMText) AsMTextDim MtxtList AsList(Of Text.StringBuilder)
Dim oDwg AsDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim oDB As DatabaseServices.Database= oDwg.Database
Dim oTransMgr As DatabaseServices.TransactionManager= oDB.TransactionManager
Dim oTrans As DatabaseServices.Transaction= oTransMgr.StartTransaction
UsingoTrans
Dim oDatabaseObject AsDBObject = oDB.BlockTableId.GetObject(DatabaseServices.OpenMode.ForRead)
Dim oBlockTable As DatabaseServices.BlockTable = DirectCast(oDatabaseObject, BlockTable)
Dim oBTRE As DatabaseServices.SymbolTableEnumerator= oBlockTable.GetEnumerator
WhileoBTRE.MoveNext
Dim oDBObject AsDBObject = oBTRE.Current.GetObject(DatabaseServices.OpenMode.ForRead)
Dim oBTR As DatabaseServices.BlockTableRecord = DirectCast(oDBObject, BlockTableRecord)
If oBTR.Name = strName.Text ThenForEach oObjectID AsObjectIdInoBTR
Dim oEnt AsDBObject = oTrans.GetObject(oObjectID, OpenMode.ForRead)
'If oEnt.GetType.ToString = "Autodesk.AutoCAD.DatabaseServices.AttributeDefinition" ThenIfTypeOf oEnt Is Autodesk.AutoCAD.DatabaseServices.MTextThen
oEnt.UpgradeOpen()
If oEnt.ToString >= ("FirstEnergy ") ThenSelectCaseCase"FirstEnergy GENERATION CORP."ReturnstrName
Case"FirstEnergy _"
GENERATION, LLC"
Return2
Case ElseThrowNewException("The border did not match any of the defined types.")
EndSelectEndIfEndIfNextEndIfEndWhile'oTrans.Commit()EndUsing
oTrans.Dispose()
oTransMgr.Dispose()
oDB.Dispose()
Return MtxtList
Replies (31)
Message 21 of 32
I tried the fist time didn't seem to be there? I did this from the Web
page. I also seen that **** wasn't there. tried to revise the post, didn't
work.
This reply was from my Email.
The information contained in this message is intended only for the
personal and confidential use of the recipient(s) named above. If
the reader of this message is not the intended recipient or an
agent responsible for delivering it to the intended recipient, you
are hereby notified that you have received this document in error
and that any review, dissemination, distribution, or copying of
this message is strictly prohibited. If you have received this
communication in error, please notify us immediately, and delete
the original message.
Message 22 of 32
I don't know why but I'm having issues with attaching the file.
Here is my next attempt
Message 23 of 32
_gile
Try this:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(CommandMethods))>
Public Class CommandMethods
    <CommandMethod("Test", CommandFlags.Modal)> _
    Public Sub Test()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim mtextClass As RXClass = RXClass.GetClass(GetType(MText))
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            If Not bt.Has("A-Size") Then
                Application.ShowAlertDialog("Block 'A-Size' not found.")
                Return
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bt("A-Size"), OpenMode.ForRead), BlockTableRecord)
            For Each id As ObjectId In btr
                If id.ObjectClass = mtextClass Then
                    Dim mtext As MText = DirectCast(tr.GetObject(id, OpenMode.ForRead), MText)
                    If mtext.Contents.Contains(" CORP.") Then
                        mtext.UpgradeOpen()
                        mtext.Contents = mtext.Contents.Replace(" CORP.", ", LLC")
            Next
            tr.Commit()
        End Using
        ed.Regen()
    End Sub
End Class
Gilles Chanteau
GileCAD
GitHub
Message 24 of 32
got your drawing. But _gile has already posted code which will serve your purpose
Message 25 of 32
_gile
Your code works as a typed command.  Im trying to figure out how to have this automatically happen when the Editor Form is loaded. The trick here is some Blocks will already be correct ,(i.e. LLC). Also this .dll is used to create new drawings, so the new drawing will be using a template file that has the correct Mtext in it (LLC).
I had this TitleBlock editor created with ALOT of help from another person. This person is no longer able to assit me with code changes since he's no longer with the company. This Post has helped me EMENSLY in understanding these concepts.
I made some changes to the code to acomodate multiple title block names, (see code below). I've tried to add this code the the Public New Sub that's part of the Form Code. I'm not sure were this belongs? In a previous post I was told to add this code to the Form Load Event. I was in the Events portion of the VB IDE trying to figure out how to do that?
Also, the below code ( in this Sub) keeps giving me a eLock error.
    Private _TitleBlockName As String = FirstEnergy.AutoCADFunctions.GetTitleBlockName
    Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
        Dim doc As Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim Sze As String = _TitleBlockName
            If Not bt.Has(Sze) Then
                ''Application.ShowAlertDialog("Block" & Sze.ToString & "Not Found")
                Return
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bt(Sze), OpenMode.ForRead), BlockTableRecord)
                        mtext.UpgradeOpen()
            Next
            tr.Commit()
        End Using
        ed.Regen()
        m_IsLoadingControls = True
        '// Init the combo boxes
        cboSCALE1.Items.AddRange(FirstEnergyEditor.Constants.DrawingScales())
        cboSCALE1.SelectedIndex = 0
        cboDWGTYPE.Items.AddRange(FirstEnergyEditor.Constants.DrawingTypes)
        cboPLANTORVENDOR.Items.AddRange(FirstEnergyEditor.Constants.PlantOrVendorTypes)
        cboDRAWINGSTATUS.Items.AddRange(FirstEnergyEditor.Constants.DrawingStatusTypes)
        cboGENTRANS.Items.AddRange(FirstEnergyEditor.Constants.GenTranTypes)
        LblOpenRev.Show()
    End Sub
Message 26 of 32
_gile
First you'd rather write a separate Sub  with one argument (the block name) so that you can call from any other place (a command method, a control event handler, an initialization method).
If you want to execute some code at AutoCAD startup, create a class which implements the IExtensionApplication interface and call the sub from the Initialize method (you must implement this method).
The way to execute a sub in each (already or newly) created document is to add an event handler for the DocumentManager.DocumentCreated event.
Make a serch with IExtensionApplication.
Gilles Chanteau
GileCAD
GitHub
Message 27 of 32
_gile
I've tried to figure out what your tell me to do. I have your code as a Sub, I've tried to place it in different locations (Namespaces) I have.
I can't seem to figure out how to tie it to the loading of form to edit the titleblock?
If I undersand your latest post, I need to create a Sub that is calling the Sub
<CommandMethod("LookForLLC")> _PublicSub LLC()? I've tried that with no success.
I see the IExtensionApplication in the object browser. But I think we may be talking about different things? All I want this code to do is change " CORP." to ", LLC" if the person opens a drawing for edit that was previously made with an older template.
As I stated earlier, the code works perfectly as  typed command.
Message 28 of 32
As you want to change mtext while document is activated so you can check the below code. in Public sub Initialize method you can see that I have add handler for ReplaceMtextinTitleBlock. This handler will be activated during your dll loading. ReplaceMtextinTitleBlock sub will be called when new document is created in Autocad editor. gile has already suggested this kind of method. Now put your code in Public Sub ReplaceMtextinTitleBlock routine and try to run the code.
Public Class MyTest
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        ed.WriteMessage("DLL loading and document created handler added")
        AddHandler Application.DocumentManager.DocumentCreated, AddressOf ReplaceMtextinTitleBlock
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        'do not need to put any code here
    End Sub
    Public Sub ReplaceMtextinTitleBlock(ByVal senderObj As Object, ByVal docColDocActEvtArgs As DocumentCollectionEventArgs)
        'put your mtext replacing code
    End Sub
End Class
Message 29 of 32
mzakiralam
I must be Dumb as a sack of dirty diapers 😞
I looked your code over and found similar code in the "MyPlugin" namespace. I added the handlers to the same location as the other handlers.
I added the Sub ReplaceMtextinTitleBlock (with minor changes to the Sze Dim) to the same namespace. All seems syntax correct.
I still don't know how to get this Sub to "Fire" when the Form frmTitleBlockEditor is loaded? Attached is the MyPlugin code.
Imports System
' This line is not mandatory, but improves loading performances
<Assembly: ExtensionApplication(GetType(TitleBlockEditorNET.MyPlugin))>
Namespace TitleBlockEditorNET
   ' This class is instantiated by AutoCAD once and kept alive for the
   ' duration of the session. If you don't do any one time initialization
   ' then you should remove this class.
   Public Class MyPlugin
      Implements IExtensionApplication
      Dim WithEvents AcadAPP As Application
      Dim WithEvents AcadDWG As Document
      Dim WithEvents AcadDM As DocumentCollection = Application.DocumentManager()
        Private _sIdleHandlerOwner As String
        Private _eDocumentLockMode As DocumentLockMode
        Dim _bTitleBlockDoubleClicked As Boolean
      Public Sub Initialize() Implements IExtensionApplication.Initialize
         'Declarations
         Dim oDwg As Document = Application.DocumentManager.MdiActiveDocument
         Dim oDM As DocumentCollection = Application.DocumentManager()
         Dim oDB As Database = oDwg.Database
            Dim oEd As Editor = oDwg.Editor
            ''AddHandler Application.DocumentManager.DocumentCreated, AddressOf ReplaceMtextinTitleBlock
         'Turn on application-level event handlers
            AddHandler Application.DocumentManager.DocumentCreated, AddressOf AcadDocumentCreated
            AddHandler Application.DocumentManager.DocumentActivated, AddressOf AcadDocumentActivated
            ''AddHandler Application.DocumentManager.DocumentCreated, AddressOf ReplaceMtextinTitleBlock()
         AddHandler Application.BeginDoubleClick, AddressOf AcadBeginDoubleClick
         'AddHandler Application.Idle, AddressOf AcadIdle
         'Turn on document-level event handlers for current drawing
         AddHandler oDM.DocumentLockModeChanged, AddressOf AcadDocumentLockModeChanged
         AddHandler oDwg.CommandEnded, AddressOf AcadDocumentCommandEnded
         AddHandler oDwg.CommandCancelled, AddressOf AcadDocumentCommandCanceled
            AddHandler oDwg.EndDwgOpen, AddressOf AcadEndDwgOpen
         'AddHandler oEd.SelectionAdded, AddressOf AcadSelectionAdded
         'Ensure FirstEnergy UI elements are loaded
            'Call modAppCommands.FECUI()
         Call modAppCommands.FECONTEXT()
      End Sub
      Public Sub Terminate() Implements IExtensionApplication.Terminate
         ' Do plug-in application clean up here
      End Sub
      Private Sub AcadDocumentCreated(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventArgs)
         'Declarations
         Dim oDB As Database = Application.DocumentManager.MdiActiveDocument.Database
         Dim oEd As Editor
         'Begin Sub
         oDwg = Application.DocumentManager.MdiActiveDocument
         If oDwg.IsReadOnly Then
            MsgBox("Drawing is read-only.")
            Return
         oEd = oDwg.Editor
         'Turn on event handlers
         AcadDWG = e.Document
         'Call modAppCommands.FECONTEXT()
      End Sub
      Sub AcadDocumentCommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs)
         'Debug.Print(e.GlobalCommandName.ToString)
         'If g_bTitleBlockDoubleClicked Then
         '   Try
         '      Dim frm As New frmTitleBlockEditor
         '      Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(frm)
         '   Catch ex As Autodesk.AutoCAD.Runtime.Exception
         '      MsgBox(ex.Message.ToString)
         '   End Try
         'End If
      End Sub
        Sub AcadDocumentCommandCanceled()
            Debug.Print("Canceled")
        End Sub
            Dim Ed As Editor = doc.Editor
            Dim Sze As String = FirstEnergy.AutoCADFunctions.GetTitleBlockName
                    Return
                            mtext.UpgradeOpen()
                Next
                tr.Commit()
            End Using
            Ed.Regen()
        End Sub
        Sub AcadBeginDoubleClick(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.BeginDoubleClickEventArgs)
            Dim oPSR As PromptSelectionResult = oEd.SelectImplied
            Dim oSS As SelectionSet = oPSR.Value
            Dim oArrayOIDs() As ObjectId
            Dim oEnt As Entity
            Dim oBlkRef As BlockReference
            If oSS Is Nothing Then
                Return
            Dim tr As Transaction = oDwg.TransactionManager.StartTransaction
            Using tr
                'Process selection set
                oArrayOIDs = oSS.GetObjectIds()
                For Each oOID In oArrayOIDs
                    oEnt = oOID.GetObject(OpenMode.ForRead)
                    If TypeOf oEnt Is BlockReference Then
                        oBlkRef = CType(oEnt, BlockReference)
                        Select Case oBlkRef.Name
                            Case "A-Size"
                                _sIdleHandlerOwner = "AcadBeginDoubleClick"
                            Case "B-Size"
                            Case "C-Size"
                            Case "D-Size"
                            Case "E-Size"
                            Case "F-Size"
                            Case "G-Size"
                            Case "X-Size"
                            Case Else
                        End Select
                        Debug.Print(oBlkRef.Name)
                Next oOID
            End Using
        End Sub
        Sub AcadIdle(ByVal sender As Object, ByVal e As System.EventArgs)
            Debug.Print("IDLE")
            RemoveHandler Application.Idle, AddressOf AcadIdle
            'Make sure FirstEnergy CUIx file is loaded on startup, then turn of handler
            If Not modAcadUI.IsPartialCuiFileLoaded("FE2011") Then
                Dim iFILEDIA As Integer = Application.GetSystemVariable("FILEDIA")
                Dim iCMDECHO As Integer = Application.GetSystemVariable("CMDECHO")
                Application.SetSystemVariable("CMDECHO", 0)
                Application.SetSystemVariable("FILEDIA", iFILEDIA)
                Application.SetSystemVariable("CMDECHO", iCMDECHO)
                'Call modAcadUI.LoadPartialCuiFile(oDwg, g_sSupportFilePath & "\FirstEnergy.cuix")
            Select Case _sIdleHandlerOwner
                Case "AcadBeginDoubleClick"
                    Try
                        _bTitleBlockDoubleClicked = False
                    End Try
                Case Else
            End Select
            _sIdleHandlerOwner = ""
        End Sub
        'Private Sub AcadSelectionAdded(ByVal sender As Object, ByVal e As SelectionAddedEventArgs)
        'End Sub 'AcadSelectionAdded
        Sub AcadDocumentLockModeChanged(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.DocumentLockModeChangedEventArgs)
            'Begin Sub
            'Set global DocumentLockMode variable
            _eDocumentLockMode = e.CurrentMode
            Select Case e.GlobalCommandName.ToString
                Case "BEDIT", "EATTEDIT", "CUILOAD"
                    If _sIdleHandlerOwner = "AcadBeginDoubleClick" Then
                        'Cancel command, turn on idle event handler, and reset flag
                        e.Veto()
                Case Else
            End Select
        End Sub
        Private Sub AcadDWG_CommandEnded(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.CommandEventArgs) Handles AcadDWG.CommandEnded
            Debug.Print("CommandEnded")
        End Sub
        Sub AcadEndDwgOpen(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.DrawingOpenEventArgs)
            'Dim oDwg As Document = Application.DocumentManager.MdiActiveDocument
            ''Make sure FirstEnergy CUIx file is loaded
            'If Not modAcadUI.IsPartialCuiFileLoaded("FirstEnergy") Then
            '   Call modAcadUI.LoadPartialCuiFile(oDwg, g_sSupportFilePath & "\FirstEnergy.cuix")
            'End If
        End Sub
        Sub AcadDocumentActivated(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.DocumentCollectionEventArgs)
            ''Turn on AppIdle event when FirstEnergy CUIx file is not loaded
            '   AddHandler Application.Idle, AddressOf AcadIdle
            'End If
        End Sub
    End Class
End Namespace
Message 30 of 32
hi,
dont be upset. As you are new in this area so it will struggling hours. It also happend to me that I did not get simple issue. Now little bit familiar with API so less problem appears while want to do something. However lets talk about the point. While DLL is loaded , our handler will be added.
  In the handler, you see that Application.DocumentManager.DocumentCreated is there. The meaning of this line is ReplaceMtextinTitleBlock sub will be fired whenever any document is created in the application. you can find details about events from .net developers guide through below link:
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff-e569a0121d1945c08-202...
I think this code should work. If not please try to debug where it is blocking. I will try with your code and your drawing as well
Message 31 of 32
mzakiralam,
After walking away and calming down. I studied the code You and _gile showed me.  I found the error!!!
I needed to change the AddHandler from this AddHandler Application.DocumentManager.DocumentCreated, AddressOf ReplaceMtextinTitleBlock to
AddHandler Application.DocumentManager.DocumentActivated, AddressOf ReplaceMtextinTitleBlock.
Thanks to everyone for the help!!!!!
I will Kudos to all involved!!!!!
THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!
Message 32 of 32
good to know that finally you have solved your problem by your own. Now you will have a good sleep 🙂
