12:20 AM
Hi ,
I have a problem while executing intersectwith between polylines and lines
the polyline execute intersectwith method referencing a line object with expandboth parameter value
but sometimes , the intersection is not found
when using expandthis or expandargument values, I have no problems
I'am using VS2012 express and Autocad 2014
the attached project containt :
an image (result;png) showing my result
a dwg file (dessin3.dwg) , it is my test file
the source code for testing , (test" command)
it find all polylines and all lines in the drawing , compute the intersections between each couple and draw a dbpoint on each
can you help me ?
thanks
Regards
Luc
