Finding a Drive letter in vb.net
GeeHaa
GeeHaa
I need to write a program to copy files from a CD to a hard drive. My problem is how can I determine what drive letter the CD is. Assuming the coping program is run from the CD.  It was easy with VBA I just embedded the macro in a drawing that was located on the CD.
Thanks in advance.
fieldguy
Soemthing like this (from http://www.a1vbcode.com/vbtip-55.asp)
Dim CDPath as String
Dim fso As New Scripting.FileSystemObject
Dim drv As Drive
For Each drv In fso.Drives
     If drv.DriveType = CDRom Then
          CDPath = drv.Path
          Exit For
     End If
Next drv
Set drv = Nothing
Set fso = Nothing
End Sub
chiefbraincloud
If what you want to know is "Where is my program running from?" then you just use My.Application.Info.DirectoryPath.
If you need your program to seek out a cd or dvd drive, then the System.IO.DriveInfo class is what you need.  This is a very quick example that will return a list (of DriveInfo) for every Optical Drive found.
 Public Function FindCD() As List(Of IO.DriveInfo)
 FindCD = New List(Of IO.DriveInfo)
 Dim alldrives As ObjectModel.ReadOnlyCollection(Of IO.DriveInfo) = Drives
 For Each DrvInfo As IO.DriveInfo In alldrives
  If DrvInfo.DriveType = IO.DriveType.CDRom Then
   FindCD.Add(DrvInfo)
  End If
 Next
End Function
Hallex
MSDN is your best friend
Take a look
http://msdn.microsoft.com/en-us/library/system.io.driveinfo.getdrives.aspx
~'J'~
Hi there,
I personaly use this:
Dim _pad As String = Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location)
This gets te location from the executing exe. Now you can trim you string. This even works when people copy the cd to there network drives.
Kind regards,
Irvin
GeeHaa
That worked, only I needed the following Imports
Imports System.IO
Imports System.Reflection
Thank You all Very Much.
