Find Rotation Angle of the current View
arcticad
Advisor Advisor
Message 1 of 13
arcticad
I'm looking to find the current rotation of my view in modelspace.
This isn't the ucs directionm but any arbitrary view i'm using.
For example using 3dorbit to rotate around an object.
I want to match some temp graphics to align flat to my view.
EDIT:
I see there is a VIEWDIR variable. so that may be what I need
(defun botsbuildbots() (botsbuildbots))
Replies (12)
Message 2 of 13
Hallex
Just a shot in the dark
GetSystemVariable("ucsxdir") maybe
~'J'~
Message 3 of 13
arcticad
ucsxdir gives me the angle of the ucs and not the angle of the view as I am currently looking at it.
Thank You for the effort. It's appreciated.
Message 4 of 13
kerry_w_brown
public Vector3d get_ViewDirection();
Declaring Type: Autodesk.AutoCAD.DatabaseServices.Viewport
Assembly: Acdbmgd, Version=18.2.0.0
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 13
arcticad
Can you give a code sample on how to access it. I'm not finding any examples.
Message 6 of 13
kerry_w_brown
This may have some info
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382...
Message 7 of 13
arcticad
I found the answer here
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
in lesson 8
Message 8 of 13
dnicholsonZCTRT
Can you share a better link? I can't find a lesson 8.
Thanks.
Message 9 of 13
Alexander.Rivilis
Thanks.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/lesson-8-bon...
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 10 of 13
at_mckinney
nobody here actually answered the question. They left little links for you to go and get it yourself, little frustrating.
Type "snapang" + enter and it'll display the current 2D view rotation. I can only answer for 2D at the moment.
Message 11 of 13
ActivistInvestor
The only thing frustrating here is that the question was answered and that You probably aren't able to recognize it, because you don't realize that this is a programming-related discussion group.
This is not an answer. This question asked ~4 years ago was about how to find the rotation angle of the current view in program code, not by issuing commands.
Message 12 of 13
dnicholsonZCTRT
This has worked for me.
1. UCS; View
2. Draw a random horizontal line in ortho mode.
3. UCS; World
4. List line rotation or set new UCS to line and save UCS (UCS; Save)
Message 13 of 13
ActivistInvestor
This discussion group is focused on programming.
The question was asked in the context of how to find out the rotation angle of the view in code, not interactively using commands,
However, the steps you outline for finding the answer interactively is the scenic route.
Command: VIEWTWIST
VIEWTWIST = 45 (read only)
