File name
File name
File name
Hi to all.
I'm trying to save two drawings sequentially with the following code:
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
<CommandMethod("SaveTwoDrawings")> _
Public Sub SaveTwoDrawings()
Dim doc As Document
Dim strDWGName As String
Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim obj As Object
doc = acDocMgr(0)
strDWGName = doc.Name
strDWGName = "c:\MyDrawing#1.dwg"
doc.Database.SaveAs(strDWGName, True, DwgVersion.Current, doc.Database.SecurityParameters)
doc = acDocMgr(1)
strDWGName = "c:\MyDrawing#2.dwg"
End Sub
End Class
While the two drawings are correctly saved in the desired position whith the desired names, only the name of the last drawing is updated ("Drawing2.dwg"--->"MyDrawing#2.dwg"), but the name of the first drawing still remains the original assigned by autocad "Drawing1.dwg", the autocad title bar is not updated too.
Some suggestions?
Alfred.NESWADBA
try to use the "Session"-flag for your command-definition:
   <CommandMethod("SaveTwoDrawings", Autodesk.AutoCAD.Runtime.CommandFlags.Session)> _
   Public Shared Sub SaveTwoDrawings()
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanks Alfred.
Tried the suggestion, but still not working.
Hi Alfred, I modified the code like this (including your suggestion).
Public Class Class1
<CommandMethod("SaveTwoDrawings", CommandFlags.Session)> _
Dim doc As Document
Dim obj As Object
doc = acDocMgr(0)
acDocMgr.MdiActiveDocument = doc
doc = acDocMgr(1)
End Sub
End Class
In this case the routine works fine.
It seems that there is a need to make the document active. When the document is active the doc.Name property is updated.
Using Autocad 2010 32bit, Visual Studio Espress 2008
