Fatal error with custom command
Ressag
Message 1 of 1
Ressag
We have a custom program that loads upon startup. When I run the command ACAD crashes with a fatal error. I stumbled upon a work around where if I manually type the NETLOAD command and then hit the CANCEL button on the dialog, then run the command, it works as expected. I only have to do this once and it works every time after (until closing and reopening ACAD). Does anyone have an answer for this behavior without needing too much more information? I'm not a developer, just an end user. Our developers are assigned to other tasks at the moment and I'm gathering info for when they can look into this.
Replies (0)
