Create Plugin
Create Plugin
guilherme.franklin
Create Plugin
guilherme.franklin
I want to develop a plugin to select a layer and create a table with the objects data, for example, the size of all circles that are in certain selected layer.
I'm new to Autocad API.NET, I'll be grateful for the help.
I'm using Autocad Civil 3D.
stefan.hofer
Here is a example for CIRCLES
In Autocad, you can use the command MYTABLE and select a object and get all circles on this layer in a table.
In your main file do something like this:
Tools.LayerToTable layerToTable = null;
[CommandMethod("MYTABLE")]
public void MyTable()
    if (layerToTable == null) { layerToTable = new Tools.LayerToTable(); }
    try
        layerToTable.GetObjectsOnLayer();
    catch (System.Exception e) { MessageBox.Show("Original error: " + e.Message); }
Then make a new file (LayerToTable.cs) and paste this code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
using System.Linq;
using System.Collections.Generic;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Colors;
using System;
namespace Tools
    public partial class LayerToTable
        public void GetObjectsOnLayer()
            // Use the active document
            Document doc = acApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            // Select a object
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.SingleOnly = true;
            pso.SinglePickInSpace = true;
            PromptSelectionResult Selection = ed.GetSelection(pso);
            if (Selection.Status == PromptStatus.OK)
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    try
                        // Get the selected entity
                        Entity SelectedEntity = (Entity)(tr.GetObject(Selection.Value.OfType<SelectedObject>().First().ObjectId, OpenMode.ForRead));
                        try
                            // Create the selection set
                            PromptSelectionResult acSSPrompt = null;
                            try
                                try
                                    TypedValue[] acTypValAr = new TypedValue[4];
                                    acTypValAr.SetValue(new TypedValue(67, 0), 0); // Model space = 0, paper space = 1
                                    acTypValAr.SetValue(new TypedValue((int)DxfCode.Visibility, 0), 1); // Visible = 0, invisible = 1
                                    acTypValAr.SetValue(new TypedValue((int)DxfCode.LayerName, SelectedEntity.Layer), 2); // Layer name
                                    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "CIRCLE"), 3); // Circle
                                    SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
                                    // Select all entities on the selected object layer
                                    acSSPrompt = ed.SelectAll(acSelFtr);
                                catch (System.Exception ex)
                                    acApp.ShowAlertDialog("Filter error. Original error: " + ex.Message);
                                if (acSSPrompt.Value.Count <= 0)
                                    acApp.ShowAlertDialog("no objects selected.");
                                    return;
                                // Create a list with all circles in the selection
                                List<Tuple<Circle, Point3d, double>> circles = new List<Tuple<Circle, Point3d, double>>();
                                try
                                    foreach (SelectedObject obj in acSSPrompt.Value)
                                        try
                                            using (Circle circle = (Circle)obj.ObjectId.GetObject(OpenMode.ForRead))
                                                circles.Add(new Tuple<Circle, Point3d, double>(circle, circle.Center, circle.Radius));
                                        catch
                                            // All objects except circles...
                                            //acApp.ShowAlertDialog("Using circle error (not a circle?)");
                                catch
                                    acApp.ShowAlertDialog("ObjectId error");
                                // Start creating the table
                                if (circles.Count > 0)
                                    try
                                        bool result = CrateTable(circles);
                                        if (!result) acApp.ShowAlertDialog("Table not created.");
                                        acApp.ShowAlertDialog("CreateTable() error. Original error: " + ex.Message);
                                else
                                    acApp.ShowAlertDialog("no circles found on this layer: " + SelectedEntity.Layer);
                                acApp.ShowAlertDialog("Select error. Original error: " + ex.Message);
                            acSSPrompt = null;
                        catch
                            acApp.ShowAlertDialog("No objects found...");
                    catch
                        acApp.ShowAlertDialog("No valid object...");
                    tr.Commit();
        private bool CrateTable(List<Tuple<Circle, Point3d, double>> circles)
            AcadDocument thisDrawing = (AcadDocument)acApp.DocumentManager.MdiActiveDocument.GetAcadDocument();
            PromptPointResult pr = ed.GetPoint("\nEnter table insertion point: ");
            if (pr.Status == PromptStatus.OK)
                // Create the table
                using (DocumentLock acLckDoc = doc.LockDocument())
                    // Layer for the table (current layer or the layername below)
                    bool useCurrentLayer = true;
                    string tableLayer = "0";
                    // Color for position text in the table
                    string strColor = string.Format("Autocad.AcCmColor.{0}", acApp.Version.Major);
                    Color posColorFromIndex = Color.FromColorIndex(ColorMethod.ByAci, 84); // 84 = dark green (autocad color index)
                    AcadAcCmColor posColor = ((AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication).GetInterfaceObject(strColor);
                    posColor.SetRGB(posColorFromIndex.ColorValue.R, posColorFromIndex.ColorValue.G, posColorFromIndex.ColorValue.B);
                    // Table layer
                    try
                        using (Transaction acTrans = db.TransactionManager.StartTransaction())
                            // Open the layer table for read
                            LayerTable acLyrTbl;
                            acLyrTbl = acTrans.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                            LayerTableRecord acLyrTblRec_Clayer = acTrans.GetObject(db.Clayer, OpenMode.ForRead) as LayerTableRecord;
                            // Abort if the layers are locked
                            if (!useCurrentLayer && acLyrTbl.Has(tableLayer) == true)
                                // Use the custom layer for the table
                                LayerTableRecord acLyrTblRec_TableLayer = acTrans.GetObject(acLyrTbl[tableLayer], OpenMode.ForRead) as LayerTableRecord;
                                if (acLyrTblRec_Clayer.IsLocked || acLyrTblRec_TableLayer.IsLocked)
                                    acApp.ShowAlertDialog("Current layer and table layer ( " + tableLayer + ") must NOT be locked!");
                                    return false;
                            else
                                // Use the current layer for the table
                                tableLayer = acLyrTblRec_Clayer.Name;
                                if (acLyrTblRec_Clayer.IsLocked)
                                    acApp.ShowAlertDialog("Current layer must NOT be locked!");
                                    return false;
                        acApp.ShowAlertDialog("Layer error. Original error: " + ex.Message);
                        return false;
                        try
                            // Rows and columns
                            int rows = circles.Count() + 4; // Title | Header + ...Entities... + Empty line | Total line (means entities + 4 rows)
                            int columns = 3;
                            // Width and height of the cells
                            double defaultRowHeight = 5.7;
                            double defaultColumnWidth = 40;
                            double positionColumnWidth = 10;
                            // Round values to...
                            int decimalPlaces = 2;
                            double[] insertPoint = { pr.Value.X, pr.Value.Y, pr.Value.Z };
                            AcadTable acTable = new AcadTable();
                            acTable = thisDrawing.ModelSpace.AddTable(insertPoint, rows, columns, defaultRowHeight, defaultColumnWidth);
                            try
                                acTable.SetTextHeight((int)AcRowType.acTitleRow, 3);
                                acTable.SetTextHeight((int)AcRowType.acHeaderRow, 2);
                                acTable.SetTextHeight((int)AcRowType.acDataRow, 2);
                                acTable.SetTextStyle((int)AcRowType.acTitleRow, "Arial");
                                acTable.SetTextStyle((int)AcRowType.acHeaderRow, "Arial");
                                acTable.SetTextStyle((int)AcRowType.acDataRow, "Arial");
                                acTable.RowHeight = defaultRowHeight;
                                acTable.Layer = tableLayer;
                                acApp.ShowAlertDialog("Error define table. Original error: " + ex.Message);
                                return false;
                            try
                                // For each row...
                                for (int i = 0; i < rows; i++)
                                    if (i == 0)
                                        // Title
                                        try
                                            acTable.SetRowHeight(i, 0.5);
                                            string title = "Object list: " + circles[0].Item1.GetType().Name;
                                            acTable.SetCellValue(i, 0, title);
                                            acTable.SetCellAlignment(i, 0, AcCellAlignment.acMiddleCenter);
                                            acApp.ShowAlertDialog("Title error: " + ex.Message);
                                            return false;
                                    else if (i == 1)
                                        // Header
                                        try
                                            for (int j = 0; j < columns; j++)
                                                if (j == 0)
                                                    // Pos.
                                                    SetTableCellValue(acTable, i, j, "Pos.", AcCellAlignment.acMiddleLeft);
                                                    acTable.SetCellContentColor(i, j, posColor);
                                                    acTable.SetColumnWidth(j, positionColumnWidth);
                                                else if (j == 1)
                                                    // Coordinates
                                                    SetTableCellValue(acTable, i, j, "Coordinates", AcCellAlignment.acMiddleLeft);
                                                    acTable.SetColumnWidth(j, defaultColumnWidth);
                                                else if (j == 2)
                                                    // Radius
                                                    SetTableCellValue(acTable, i, j, "Radius", AcCellAlignment.acMiddleLeft);
                                            acApp.ShowAlertDialog("Header error: " + ex.Message);
                                            return false;
                                    else if (i == circles.Count() + 2)
                                        // Empty line below before the total line
                                        try
                                            acTable.VertCellMargin = 0;
                                            acTable.MergeCells(i, i, 0, acTable.Columns - 1);
                                            continue;
                                            acApp.ShowAlertDialog("Emptyline error: " + ex.Message);
                                            return false;
                                    else if (i == circles.Count() + 3)
                                        // Total line below
                                        try
                                            acTable.SetRowHeight(i, defaultRowHeight);
                                            SetTableCellValue(acTable, i, 0, "Total: " + circles.Count().ToString(), AcCellAlignment.acMiddleLeft);
                                            continue;
                                            acApp.ShowAlertDialog("Totelline error: " + ex.Message);
                                            return false;
                                    else
                                        // All entity lines
                                        try
                                                if (j == 0)
                                                    // Pos.
                                                    SetTableCellValue(acTable, i, j, (i - 1).ToString(), AcCellAlignment.acMiddleLeft);
                                                else if (j == 1)
                                                    // Coordinates
                                                    Point3d center = circles[i - 2].Item2;
                                                    string xyzText = Math.Round(center.X, decimalPlaces).ToString() + ","
                                                        + Math.Round(center.Y, decimalPlaces).ToString() + ","
                                                        + Math.Round(center.Z, decimalPlaces).ToString();
                                                    SetTableCellValue(acTable, i, j, xyzText, AcCellAlignment.acMiddleRight);
                                                else if (j == 2)
                                                    // Radius
                                                    string radiusText = Math.Round(circles[i - 2].Item3, decimalPlaces).ToString();
                                                    SetTableCellValue(acTable, i, j, radiusText, AcCellAlignment.acMiddleRight);
                                            acApp.ShowAlertDialog("Entity error: " + ex.Message);
                                            return false;
                                acApp.ShowAlertDialog("Fill table cells error: Original error: " + ex.Message);
                                return false;
                            acApp.ShowAlertDialog("AcadTable error: " + ex.Message);
                            return false;
                        acTrans.Commit();
            return true;
        private void SetTableCellValue(AcadTable table, int r, int c, string value, AcCellAlignment alignment)
            table.SetCellValue(r, c, value);
            table.SetCellAlignment(r, c, alignment);
guilherme.franklin
I did everything as per your instructions, however, I can't find it by running the "MYTABLE" command in Civil3D.Main fileMain fileLayerToTableLayerToTable
stefan.hofer
Your main file should look something like this one:
using System;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(Tools.index))]
namespace Tools
    public class index : IExtensionApplication
        public void Initialize() { }
        public void Terminate() { throw new NotImplementedException(); }
            try
And you have to load this dll in autocad with the NETLOAD command. (or load it with a lisp file on startup)
guilherme.franklin
I managed to execute, however, when inserting the points of the table I could not understand the code execution.select layersselect layersinsert table pointsinsert table pointserror defining tableerror defining table
stefan.hofer
key not found?
i don't use civil. pearhaps in civil some table keys don't exist.
try
    return false;
I think (int)acRowType is the key.
you can try to comment out those lines. but i can't say exactly what the problem is.
guilherme.franklin
I understand. You helped me a lot, thank you very much.
