fatal error on selectwindowpolygon
I try to select an polyline (with always 4 corners).
Then I need to select everything within the polyline.
So far so good.
But when i try to access the selectionset i get an fatal error.
I don't no how to solve it.
I hope that someone can help me.
Greetings Jacco
    Public Sub CrossingPolygonSelect()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acDocEd As Editor = acDoc.Editor
        Dim prObjectOptions As PromptEntityOptions = New PromptEntityOptions("Selecteer het aan te sluiten profiel : ")
        Dim pt As Object
        prObjectOptions.SetRejectMessage(vbLf + "Je moet een profiel selecteren" + vbLf)
        prObjectOptions.AllowNone = False
        pt = acDocEd.GetEntity(prObjectOptions)
        If pt.Status <> PromptStatus.OK Then Exit Sub
        Dim prof1 As ObjectId = pt.objectid
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim ent0 As Polyline2d = acTrans.GetObject(prof1, OpenMode.ForRead)
            Dim acPts3d As Point3dCollection = New Point3dCollection()
            Dim pt0 As Point3d
            pt0 = ent0.GetPointAtParameter(0)
            acPts3d.Add(pt0)
            pt0 = ent0.GetPointAtParameter(1)
            acPts3d.Add(pt0)
            pt0 = ent0.GetPointAtParameter(2)
            acPts3d.Add(pt0)
            pt0 = ent0.GetPointAtParameter(3)
            acPts3d.Add(pt0)
            Dim sres As PromptSelectionResult = acDocEd.SelectWindowPolygon(acPts3d) ', filter)
            Dim acSSet As SelectionSet
            acSSet = sres.Value
            For Each acSSObj As SelectedObject In acSSet
                MsgBox(acSSObj.ObjectId)
            Next
            acTrans.Commit()
        End Using
    End Sub
norman.yuan
When you say "So far so good", how far the code goes until it is not good? Have you done debugging line by line/with break point? This way you can easily tell which line of code does the bad thing.
Just from your code without see the drawing, it i shard to tell what is wrong. But if I have to guess, it could be this line:
Are you sure the picked polyline is Polyline2d, not Polyline? Polyline in .NET API is equivalent to AcadLWPolyline in VBA, which is used to replace old AutoCAD polylne (Polyline2d in .NET API) years ago. That is, Polyline2d/AcadPolyline only exists for backward compatibility since many versions of AutoCAD back (R13/13/14? I cannot remember). So, the picked polyline should be either Polyline or Polyline3d (in .NET API).
Norman Yuan
Drive CAD With Code
In agreement with Norman, I would suggest a fail safe in your code:
dim pline as polyline
dim ent as entitiy = trans.getobject(selectedobject.objectid,openmode.forread)
'use the if typeof line to test the object that was selected...
if typeof ent is AutoDesk.AutoCAD.DatabaseServices.Polyline then
pline = ent
end if
Hallex
Try this code
I think you have to add Try..Catch to easier search for a problem
code line
        Public Sub WindowPolygonSelect()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim pso As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select a contour : ")
            Dim res As PromptEntityResult
            pso.SetRejectMessage(vbLf & "You must select a polyline only" & vbLf)
            pso.AllowNone = False
            res = ed.GetEntity(pso)
            If res.Status <> PromptStatus.OK Then Exit Sub
            Dim id As ObjectId = res.ObjectId
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim ent As Polyline = TryCast(tr.GetObject(id, OpenMode.ForRead), Polyline)
                Dim pts As Point3dCollection = New Point3dCollection()
                Dim p As Point3d
                Dim i As Integer = 0
                For i = 0 To ent.NumberOfVertices - 1
                    p = ent.GetPoint3dAt(i)
                    pts.Add(p)
                Next
                Dim sres As PromptSelectionResult = ed.SelectWindowPolygon(pts) ', filter)
                Dim ss As SelectionSet
                ss = sres.Value
                For Each ssobj As SelectedObject In ss
                    Dim obj As Entity = DirectCast(tr.GetObject(ssobj.ObjectId, OpenMode.ForRead), Entity)
                    ed.WriteMessage(vbLf & "{0}" & vbTab & "{1}", obj.ObjectId, obj.GetRXClass().Name)
                Next
                tr.Commit()
            End Using
        End Sub
