F1 Help Button open CHM Html
Hi
I have got a button that i have changed the F1 to open my open CHM File
The only problem is it opens the file but looks for htm and the files within mine chm are html
Is there any way of telling in to look for the html file and not just htm?
Button.HelpSource = New Uri(Install_Loc)
Button.HelpTopic = "store"
 Basicaly is looks for the location of the help file
and then the name of the page which in the example above is "store"
And then opens the chm file with the store page but at the moment it is doing "store.htm" and not html
Thanks In Advance
James
owenwengerd
It sounds like you have an incorrect topic mapping in your help file.
Owen Wengerd
ManuSoft
My help file works fine
Its just that the files behind it have been compiled as HTML and not htm
We have tested it by chnaging one of the pages to be htm to see if it would work and it does it opens on the correct page
as it is now a htm file
Its just adding the extension .htm on the end of the topic and i want it to add html
or its the only option to convert all the pages to htm ?
owenwengerd
Other things to try:
1) Add the .html extension to your topic string.
2) Create or correct your help file's keyword/topic map.
Owen Wengerd
ManuSoft
Have just had a look at that
If I put
button.HelpTopic = "Photos"
It opens the CHM to photo's.htm
If I was to change it to
button.HelpTopic = "Photos.html"
It opens the CHM to photo's.html.htm
I have checked the Topic map and the photo's one has just got the word photo's
NOTE: The information in this email may be confidential and legally
privileged. If you are not the intended recipient, you must not
read, use or disseminate the information; please advise the sender
immediately by reply email and delete this message and any
attachments without retaining a copy. Although this email and any
attachments are believed to be free of any virus or other defect
that may affect any computer system into which it is received and
opened, it is the responsibility of the recipient to ensure that it
is virus free and no responsibility is accepted by RGIS, LLC for
any loss or damage arising in any way from its use.
