Extend lines without crossing
Dan-Rod
Dan-Rod
Hello, I have a problem with some lines that an automatic system throws me with a macro (the programmer who designed the macro is no longer there), the set of lines represent a wiring, on the left side of the annex is the input that launches the macro. set of lines and to the right as I want it to be, to find out if there is a way (some macro within autocad) to open the lines at the greatest possible angle and prevent them from colliding with each other when they open, there are continuous lines that just need to be straight.
In case there is not something inside the program, some code that can help me.
I hope you can support me.
pendean
Community Legend
Community Legend
Where is the macro code @Dan-Rod
Dan-Rod
I only leave the buttons and a dll, apparently it was done in .NET, It won't let me share the dll here
Kent1Cooper
@Dan-Rod wrote:
..., It won't let me share the dll here
Put it into a .ZIP file, and you can attach that.
Kent Cooper, AIA
Dan-Rod
is what I have
