Export to .dwfx using .net API
chockalingam
chockalingam
 I want to export .dwg file to .dwfx using .net api, can any one help me in solving this issue.
Within your plot routine do something like this:
PlotSettings ps_base = (PlotSettings)t.GetObject(ObjectId_of_Layout, OpenMode.ForWrite);
PlotSettingsValidator psv = Autodesk.AutoCAD.DatabaseServices.PlotSettingsValidator.Current;
psv.SetPlotConfigurationName(ps_base, "DWFx ePlot (XPS Compatible).pc3", null);
r,
dennis
Hallex
Try code written by Balaji Ram from there
http://forums.autodesk.com/t5/NET/How-to-use-Export-API-for-autocad-document-object/m-p/3618168/high...
just in case if you have DwgPreView installed
and also change file extension on what you need
