Error "Operation is not valid due to the current state of the object"
rtejada
rtejada
Hi all,
I am getting the "Operation is not valid due to the current state of the object" when doing the following
dim db as New Database (False, True)
db.ReadDwgFile(myfilename,FileOpenMode.OpenforReadAndAllShare,False,Nothing)
db.ResolveXrefs(True,False)
dim tm as Transaction = db.TransactionManager.StartTransaction()
the next line is the one that crashes
dim myDoc as Document = DocumentManager.GetDocument(db)
the line works with the working database, but I need it to work with an unopenned drawing. Is it possible?
Thanks in advance.
Raul
It's my understanding that opening a drawing in the background via ReadDwgFile only opens the drawing's database and doesn't create a document object. In order to access a document you need to open it first.
I would consider whether you really need to open the document into the document collection, and if you do i would open it and set the window.visible property to false.
{code}
Dim doc As Document = Application.DocumentManager.Open(mydrawingfilename, True, "")
doc.Window.Visible = False
{code}
-Mark P.
A Database that's not open in the editor has no associated Document.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:[email protected]...
Hi all,
Thanks in advance.
Raul
rtejada
Thanks Mark for the visible trick and thanks Tony, I will look into a "open in the editor" sample, may be more efficient.
