Error installing Addin
I created an Setup project to install my AutoCAD Addin, based in your code
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS73099cc1...
"Develop Applications with VB.NET and C# / Distribute Your Application"
You can see my code below.
I get the following error in the installation
using System;
using System.Collections;
using System.Collections.Generic;
using System.ComponentModel;
using System.Configuration.Install;
using System.Linq;
using System.IO;
using System.Reflection;
using Microsoft.Win32;
using Autodesk.AutoCAD.DatabaseServices;
namespace eGrouWSAutoCADAddin
    [RunInstaller(true)]
    public partial class AddinInstaller : System.Configuration.Install.Installer
        StreamWriter icl_installLog;
        public AddinInstaller()
            InitializeComponent();
        public override void Install(System.Collections.IDictionary stateSaver)
            // Gets the parameter passed across in the CustomActionData.
            icl_installLog = new StreamWriter("_eGrouWSAutoCADAddInSetup.log");
            icl_installLog.AutoFlush = true;
            try
                m_InstallAddin(stateSaver);
            finally
                icl_installLog.WriteLine("Ending edit of config file");
                icl_installLog.Close();
        public void m_InstallAddin(System.Collections.IDictionary stateSaver)
            try
                base.Install(stateSaver);
                // Get the AutoCAD Applications key
                string sProdKey = HostApplicationServices.Current.MachineRegistryProductRootKey;
                string sAppName = "eGrouWSAutoCADAddin";
                RegistryKey regAcadProdKey = Registry.CurrentUser.OpenSubKey(sProdKey);
                RegistryKey regAcadAppKey = regAcadProdKey.OpenSubKey("Applications", true);
                // Check to see if the "MyApp" key exists
                string[] subKeys = regAcadAppKey.GetSubKeyNames();
                foreach (string subKey in subKeys)
                    // If the application is already registered, exit
                    if (subKey.Equals(sAppName))
                        regAcadAppKey.Close();
                        return;
                // Get the location of this module
                string sAssemblyPath = Assembly.GetExecutingAssembly().Location;
                // Register the application
                RegistryKey regAppAddInKey = regAcadAppKey.CreateSubKey(sAppName);
                regAppAddInKey.SetValue("DESCRIPTION", sAppName, RegistryValueKind.String);
                regAppAddInKey.SetValue("LOADCTRLS", 14, RegistryValueKind.DWord);
                regAppAddInKey.SetValue("LOADER", sAssemblyPath, RegistryValueKind.String);
                regAppAddInKey.SetValue("MANAGED", 1, RegistryValueKind.DWord);
            catch (InstallException ex)
                throw new InstallException(ex.Message);
            catch
                throw new InstallException("Error installing addin!");
        public override void Uninstall(System.Collections.IDictionary stateSaver)
            icl_installLog = new StreamWriter("eGrouWSAutoCADAddin.log");
            try
                m_UninstallAddin(stateSaver);
            finally
        public void m_UninstallAddin(IDictionary savedState)
            try
                // Delete the key for the application
                regAcadAppKey.DeleteSubKeyTree(sAppName);
            catch
            base.Uninstall(savedState);
