Erasing Layouts
Erasing Layouts
s.jabs
Message 1 of 21
Erasing Layouts
s.jabs
Does anyone have an example of how to properly remove a layout? I'm writing a routine to strip down drawings to an optimized (and standardized) format, but I'm having trouble with this one bit of code:
{code}
Protected Friend Shared Sub RemoveLayouts(ByVal dbAcad As Database)
Dim edCmdLine As Editor = AcApp.Application.DocumentManager.MdiActiveDocument.Editor
Dim alLayouts As ArrayList = New ArrayList()
Dim lmAcad As LayoutManager = LayoutManager.Current
Dim oiTemp As ObjectId
Try
' Create empty layout to satisfy one minimum layout requirement
oiTemp = lmAcad.CreateLayout("Some-Random-Name")
Using trAcad As Transaction = dbAcad.TransactionManager.StartTransaction()
Dim deItem As DictionaryEntry
Dim dicLayouts As DBDictionary = DirectCast(trAcad.GetObject(dbAcad.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
Dim intI As Integer
Dim lItem As Layout
Dim oiBlock As ObjectId
Dim oicViewports As ObjectIdCollection
Dim vItem As Viewport
' Get the list of layouts
For Each deItem In dicLayouts
alLayouts.Add(DirectCast(trAcad.GetObject(CType(deItem.Value, ObjectId), OpenMode.ForRead), Layout).LayoutName)
Next
' Cycle through the layouts, deleting all but model space and one layout
For intI = 0 To alLayouts.Count - 1
If alLayouts(intI) <> "Model" And alLayouts(intI) <> "Some-Random-Name" Then
Try
lItem = DirectCast(trAcad.GetObject(lmAcad.GetLayoutId(alLayouts(intI)), OpenMode.ForWrite), Layout)
oiBlock = lItem.BlockTableRecordId
' Deals with viewports
oicViewports = lItem.GetViewports()
For Each oiViewport In oicViewports
vItem = DirectCast(trAcad.GetObject(oiViewport, OpenMode.ForWrite), Viewport)
vItem.Erase()
Next
lmAcad.DeleteLayout(lItem.LayoutName)
Catch ex As Exception
End Try
End If
Next
trAcad.Commit()
End Using
Dim lItem As Layout
lItem = DirectCast(trAcad.GetObject(oiTemp, OpenMode.ForWrite), Layout)
lItem.Initialize()
lItem.LayoutName = "Layout1"
trAcad.Commit()
End Using
End Try
End Sub
{code}
If I don't remove the viewports "manually", I get drawing corruption. If the layout to be removed contains a block with attribute definitions, that too causes corruption. If I get the BlockTableRecord from the layout, and erase it instead, I don't get corruption, but the drawing crashes when I switch layout tabs.
Replies (20)
Message 21 of 21
SENL1362
Before (in AutoCAD MAP 2014):
        [CommandMethod("TestDelLayout")]
        public void TestDelLayout()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                doc = AcadApp.DocumentManager.MdiActiveDocument;
                db = doc.Database;
                ed = doc.Editor;
                var layoutManager=LayoutManager.Current;
                //Get the Layouts in the order visible to the user;
                //Delete the default Layers, Layout*
                foreach (string layoutName in GetTabOrderedLayoutNames(db))
                    if (Regex.IsMatch(layoutName,"^LAYOUT[0-9]+", RegexOptions.IgnoreCase))
                        layoutManager.DeleteLayout(layoutName);
                ed.Regen();
            catch (System.Exception ex)
                if (ed != null)
                    ed.WriteMessage("\n Error: " + ex.Message);
                else
                    MessageBox.Show("Error: " + ex.Message, "TestDelLayout", MessageBoxButtons.OK, MessageBoxIcon.Error);
        public static List<string> GetTabOrderedLayoutNames(Database db)
            if (db == null)
                return null;
            var tabOrderedLayouts = new Dictionary<int, string>();
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry layoutEntry in layoutDict)
                    Layout layout = (Layout)tr.GetObject(layoutEntry.Value, OpenMode.ForRead);
                    if (!layout.ModelType)
                    tabOrderedLayouts[layout.TabOrder] = layout.LayoutName;
                tr.Commit();
            return tabOrderedLayouts.OrderBy(n => n.Key).Select(n => n.Value).ToList();
After:
No Commit in the "Delete" procedure only ed.Regen();
