Ending My Command
Ending My Command
Amremad
Ending My Command
Amremad
 Public Shared Sub ChengeBlock()
        Dim TypedValues(0) As TypedValue
            TypedValues.SetValue(New TypedValue(DxfCode.BlockName, MObject), 0)
        Dim AcSelFtr As SelectionFilter = New SelectionFilter(TypedValues)
        Dim AcSelOption As PromptSelectionOptions = New PromptSelectionOptions
        AcSelOption.Keywords.Add("Object")
        AcSelOption.Keywords.Add("Factor")
        AcSelOption.Keywords.Add("Type")
        AcSelOption.MessageForAdding = (vbLf & "Select Object(s) or " & AcSelOption.Keywords.GetDisplayString(True))
        AcSelOption.Keywords.Default = "Object"
        AddHandler AcSelOption.KeywordInput, AddressOf handle_KeywordInput
        Dim AcSelResult As PromptSelectionResult = Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(AcSelOption, AcSelFtr)
	' I Need to Exit here from this function without canceled by user
        If AcSelResult.Status = PromptStatus.OK Then
        End If
    End Sub
fenton_webb
just put a return statement in the code
Fenton Webb
AutoCAD Engineering
Amremad
no mr fenton
to execute the return statmen , the GetSelection must execute first ,
just i need to cancel GetSelection function without user , just by me
any why my completely code i will put in the next replay
Amremad
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Public NotInheritable Class ChangeBlocks
    Private Shared MObject As String
    Private Shared Factor As Double
    Private Shared Modification As String
    Private Shared Type As String
    Private Shared TypedValues(0) As TypedValue
    Private Shared AcSelFtr As SelectionFilter
    Private Shared LFormat As String
        MObject = GetSetting("AMR LISP", "Chenge Block", "Object", "ALL")
        Factor = GetSetting("AMR LISP", "Chenge Block", "Factor", "0")
        Type = GetSetting("AMR LISP", "Chenge Block", "Type", "Text")
        LFormat = GetSetting("AMR LISP", "Check Level", "Format", "0.00")
        ' create selection filter with typedvalues
        'Dim TypedValues(0) As TypedValue
        If MObject = "All" Then
            TypedValues.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
        Else
        End If
        AcSelFtr = New SelectionFilter(TypedValues)
        'create keywords options for selection
        AcSelOption.Keywords.Add("FActor")
        AcSelOption.Keywords.Add("FOrmat")
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
            If Type = "Text" Then
                If ChangeText(AcSelResult.Value) = False Then
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "invalid operation, try again")
                End If
            Else
                If EditScale(AcSelResult.Value) = False Then
                End If
            End If
        End If
        Tr.Commit()
        Tr.Dispose()
        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "done")
    End Sub
    Private Shared Function ChangeText(MySelSet As SelectionSet) As Boolean
        If MySelSet IsNot Nothing Then
            For Each BlKID In MySelSet.GetObjectIds()
                Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
                If BlkRef.AttributeCollection.Count > 0 Then
                    Dim objId As ObjectId = BlkRef.AttributeCollection.Item(0)
                    Dim attRef As AttributeReference = Tr.GetObject(objId, OpenMode.ForWrite)
                    Dim Value As Double = Val(attRef.TextString) + Factor
                    If Value = 0 Then
                        attRef.TextString = "±" & Format(Value, LFormat)
                    ElseIf Value > 0 Then
                        attRef.TextString = "+" & Format(Value, LFormat)
                    ElseIf Value < 0 Then
                        attRef.TextString = Format(Value, LFormat)
                    End If
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
        Return True
    End Function
    Private Shared Function EditScale(MySelSet As SelectionSet) As Boolean
                If Factor > 0 Then
                    BlkRef.TransformBy(Matrix3d.Scaling(Factor, BlkRef.Position))
                Else
                    Return False
                End If
            Next
        End If
        Tr.Commit()
        Tr.Dispose()
        Return True
    End Function
    Private Shared Sub handle_KeywordInput(ByVal sender As Object, ByVal e As SelectionTextInputEventArgs)
        Select Case e.Input
            Case "Object"
                Dim Trans As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
                Dim AcEntOption As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select base object")
                AcEntOption.Keywords.Add("All")
                AcEntOption.Keywords.Add(MObject)
                AcEntOption.Keywords(1).Visible = False
                AcEntOption.Keywords.Default = MObject
                AcEntOption.SetRejectMessage(vbLf & "You must pick a block , try again ...")
                AcEntOption.AddAllowedClass(GetType(BlockReference), True)
                Dim AcEntResult As PromptEntityResult = Application.DocumentManager.MdiActiveDocument.Editor.GetEntity(AcEntOption)
                If AcEntResult.Status = PromptStatus.OK Then
                    Dim Obj As DBObject = Trans.GetObject(AcEntResult.ObjectId, OpenMode.ForRead)
                    If TypeOf (Obj) Is BlockReference Then
                        Dim Source As BlockReference = Obj
                        MObject = Source.Name
                        SaveSetting("AMR LISP", "Chenge Block", "Object", MObject)
                        'TypedValues.SetValue(New TypedValue(DxfCode.Start, MObject), 0)
                        'AcSelFtr = New SelectionFilter(TypedValues)
                    End If
                ElseIf AcEntResult.Status = PromptStatus.Keyword Then
                    Select Case AcEntResult.StringResult
                        Case "All"
                            MObject = "All"
                            'TypedValues.SetValue(New TypedValue(DxfCode.BlockName, MObject), 0)
                    End Select
                Else
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "you are selected unsupported object")
                End If
                Trans.Commit()
                Trans.Dispose()
            Case "FActor"
L2:             Dim AcDblOption As PromptDoubleOptions = New PromptDoubleOptions(vbLf & "Enter the calculation unit (Meter Unit) ")
                AcDblOption.AllowNone = False
                AcDblOption.DefaultValue = Factor
                    AcDblOption.AllowNegative = True
                Else
                    AcDblOption.AllowNegative = False
                End If
                Dim AcDblResult As PromptDoubleResult = Application.DocumentManager.MdiActiveDocument.Editor.GetDouble(AcDblOption)
                If AcDblResult.Status = PromptStatus.OK Then
                    If Type = "Size" And AcDblResult.Value <= 0 Then
                        Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & "Value must be positive.")
                        GoTo L2
                    End If
                    Factor = AcDblResult.Value
                    SaveSetting("AMR LISP", "Chenge Block", "Factor", Factor)
                Else
                End If
            Case "Type"
                Dim AcKwrdOption2 As PromptKeywordOptions = New PromptKeywordOptions(vbLf & "Which method you will use  [Text/Size] : ", "Text Size")
                AcKwrdOption2.Keywords.Default = Type
                Dim AcKwrdResult2 As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetKeywords(AcKwrdOption2)
                If AcKwrdResult2.Status = PromptStatus.OK Then
                    Type = AcKwrdResult2.StringResult
                    SaveSetting("AMR LISP", "Chenge Block", "Type", Type)
                End If
            Case "FOrmat"
                Dim AcStrOption As PromptStringOptions = New PromptStringOptions("Enter text format that you want :")
                AcStrOption.DefaultValue = LFormat
                Dim AcStrResult As PromptResult = Application.DocumentManager.MdiActiveDocument.Editor.GetString(AcStrOption)
                If AcStrResult.Status = PromptStatus.OK Then
                    LFormat = AcStrResult.StringResult
                    SaveSetting("AMR LISP", "Chenge Block", "Format", LFormat)
                End If
        End Select
    End Sub
End Class
this code can edit all block size , or block attributes text
my problem if the user while selection change the block name , so i need to apply the new filter to current selection ,
or cancel selection by code, or any solution to fix this problem
augusto.goncalves
You can cancel (by code) an active command on AutoCAD, but you may need an additional logic to decide when to cancel it.
Check at http://through-the-interface.typepad.com/through_the_interface/2006/08/cancelling_an_a.html
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Did you have any luck with this, I am having the same issue, I want to exit out of select object when a keyword is entered.
Kind Regards
David
