eInvalidInput While Setting Attachment of MText
Abby_Baratta
Abby_Baratta
Hi!
I've been working on a function that will insert text into the active document and I wanted to edit the attachment point. I've tried it two different ways, but I am still seeing the eInvalidInput error. The function that I have written is as follows:
        internal static void AddSomeText(string txt, double txtHeight ,Point3d txtLoc, string layerName)
            //call func to create layer name, in case it's not in there yet
            AssignLayer(layerName);
            //document and database
            acAppServ.Document acDoc = acAppServ.Application.DocumentManager.MdiActiveDocument;
            Database acCurDB = acDoc.Database;
            //transaction
            using (Transaction acTr = acCurDB.TransactionManager.StartTransaction())
                using (DocumentLock docLock = acDoc.LockDocument())
                    //block table and block table record
                    BlockTable acBlkTbl = acTr.GetObject(acCurDB.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord acBlkTblRec = acTr.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    //create multiline text object
                    using (MText acMText = new MText())
                        acMText.Location = txtLoc;
                        acMText.TextHeight = txtHeight;
                        acMText.Layer = layerName;
                        //acMText.Attachment = AttachmentPoint.MiddleAlign;
                        acMText.SetAttachmentMovingLocation(AttachmentPoint.MiddleAlign);
                        acMText.Contents = txt;
                        acBlkTblRec.AppendEntity(acMText);
                        acTr.AddNewlyCreatedDBObject(acMText, true);
                acTr.Commit();
            acAppServ.Application.DocumentManager.MdiActiveDocument.Editor.Regen();
Where acAppServ is Autodesk.AutoCAD.ApplicationServices
I would really appreciate any help on how to properly set this this property!
daniel_cadext
MiddleAlign is not one of the allowed options
https://forums.autodesk.com/t5/net-forum/einvalidinput-while-setting-attachment-of-mtext/td-p/136561...
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
_gile
@daniel_cadext Isn't that the link you wanted to give?
https://help.autodesk.com/view/OARX/2025/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseSer...
Gilles Chanteau
GileCAD
GitHub
Abby_Baratta
Ah, yeah changing it to one of those in that list worked. Thanks!
