eInvalidInput while reading block attributes
Trying to read block attributes from drawing gives me eInvalidInput most of the time
I don't really understand this error
This was working fine 2 days ago and now is just failing most of the time.
Anyone could help me out. The class Atribute map is just a simple Key/Value pair class that store the block attributes.
this is the code is failing
/// <see cref="https://forums.autodesk.com/t5/net/find-block-inside-a-polyline/td-p/7586489"/>
public static IEnumerable<AttributeMap> GetBlockAttributesInsidePolyline(ObjectId id)
Document doc = Application.DocumentManager.MdiActiveDocument;
doc.LockDocument();
Database db = doc.Database;
Editor ed = doc.Editor;
ObjectId[] ids = null;
using (Transaction tr = db.TransactionManager.StartTransaction())
try
Polyline pline = (Polyline)tr.GetObject(id, OpenMode.ForRead);
PromptSelectionResult selection = ed.SelectByPolyline(pline, PolygonSelectionMode.Window, new TypedValue(0, "INSERT"));
if (selection.Status == PromptStatus.OK)
ed.SetImpliedSelection(selection.Value);
ids = selection.Value.GetObjectIds(); ----------->here is whare it hapens most of the time---------------------------------------
catch (Autodesk.AutoCAD.Runtime.Exception e)
Controller.TagController.CurrentDrawing.Logger.Error(string.Format("Polyline Handle {0} had an error: {1} ",
id.Handle.ToString(), e.Message));
return GetBlockAttributes(ids);
/// <see cref="http://through-the-interface.typepad.com/through_the_interface/2006/09/getting_autocad.html"/>
/// <param name="ids">ObjectIds</param>
public static IEnumerable<AttributeMap> GetBlockAttributes(ObjectId[] ids)
//There should be just one object Id in the ids
doc.LockDocument();
List<AttributeMap> attributes = new List<AttributeMap>();
if (ids != null)
using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
foreach (ObjectId id in ids)
BlockReference blkRef = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead);
Controller.TagController.CurrentDrawing.Logger.Info("Block: " + btr.Name);
btr.Dispose();
AttributeCollection attCol = blkRef.AttributeCollection;
foreach (ObjectId attId in attCol)
AttributeReference attRef = (AttributeReference)tr.GetObject(attId, OpenMode.ForRead);
string str = string.Format(" Attribute Tag: {0}{1} Attribute String: {2}", attRef.Tag, System.Environment.NewLine, attRef.TextString);
Controller.TagController.CurrentDrawing.Logger.Info(str);
attributes.Add(new AttributeMap { Field = attRef.Tag, Value = attRef.TextString });
tr.Commit();
return attributes;
_gile
doc.LockDocument();
try
Try removing: ed.SetImpliedSelection(selection.Value);
This expression was only a way to display the result of the selection in the example.
Gilles Chanteau
GileCAD
GitHub
Juergen_Becker
in which line does the error accure?
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Thank once again,that seems to solved it.
Just for curiosity why that line may be causing the issue?.
I couldn't find in the reference document that method.
_gile
After calling Editor.SetImpliedSelection, the selection set entities are highlighted/gripped, in other words, the selection set is "opened" for adding or removing entities to it. That's why you cannot acces to the SelectionSet.GetObjectIds() method.
Gilles Chanteau
GileCAD
GitHub
