eFileAccessErr, ePermanentlyErased, eInvalidInput when ResolveXrefs
wesbird
Message 1 of 1
wesbird
Hi, I’m working on a project of renaming Xref for about 1000+ drawings. Most of Xrefs is in a pattern of:
A <- B <- C
A <- D <- B <- C
My plan is:
1. Rename C first
2. Open B in side DB, repath C from old to new, save B as new name, del old B
3. Then do the same for D
4. Then do the same for A
Now the code report error messages below on some file not all, and not repeat at certain file(s).
  • eFileAccessErr
  • ePermanentlyErased
  • eInvalidInput
At
ResolveXrefs at line 16 or 42.
I figure the reason is, after C and B be renamed, when open A or D (in side DB), it still look for old C, which already be renamed. most time AutoCAD  will purge old C automatically. but it will throw error some time.
I cannot approve my theory, have anybody had the similar issue and how to handle it properly?
Or could be any other reason I did not know?
Thank a lot for your time. Any help will be appreciated.
Wes
Here is my code
using Autodesk.AutoCAD.DatabaseServices;
using System;
using System.Collections.Generic;
namespace Acad1
    class Class2
        public bool Repath(Database db, List<RenameXref> rxXrefs)
            bool retSaveHost = false;
            try
                db.UsingTransaction(tr =>
                    db.ResolveXrefs(true, false);
                    var XrGph = db.GetHostDwgXrefGraph(true);
                    for (int i = 1; i < XrGph.NumNodes; ++i)
                        var XrNode = XrGph.GetXrefNode(i);
                        var btr = XrNode.BlockTableRecordId.GetObject<BlockTableRecord>(OpenMode.ForWrite);
                        string oldPathName = btr.PathName;
                        ObjectIdCollection oids = new ObjectIdCollection();
                        foreach (var rxXref in rxXrefs)
                            string newPathName = GetNewPathName(oldPathName, rxXref);
                            if (!string.IsNullOrEmpty(newPathName))
                                btr.PathName = newPathName;
                                btr.Name = rxXref.NewWithoutExt;
                                oids.Add(btr.ObjectId);
                                break;
                        if (oids.Count > 0)
                            db.XrefEditEnabled = true;
                            db.ReloadXrefs(oids);
                            retSaveHost = true;
                return retSaveHost;
            catch (Exception)
                return false;
        public static string GetNewPathName(string oldPathName, RenameXref rxXref)
            string PathName = "";
            // ... rename logic goes here
            PathName = $@".\{rxXref.NewName}";
            return PathName;
here is code of open side DB
        public static Database OpenSideDB(this string dwgFileName, FileOpenMode fom = FileOpenMode.OpenForReadAndAllShare)
            if (!File.Exists(dwgFileName))
                return null;
            Database db = null;
            try
                db = new Database(false, true);
                db.ReadDwgFile(dwgFileName, fom, true, null);
                db.CloseInput(true);
            catch (Exception)
                // error handler
            return db;
here is related code:
using System.IO;
namespace Acad1
    public class RenameXref
        #region
        public string Old { get; private set; }
        public string OldXref { get; private set; }
        public string NewXref { get; private set; }
        public bool FoundOld { get; private set; }
        public string Lyr { get; private set; }
        public string NewName
            get
                return Path.GetFileName(NewXref);
        public string NewWithoutExt
            get
                return Path.GetFileNameWithoutExtension(NewXref);
        #endregion
        #region ctor
        private RenameXref(string myOld, string myOldXref, string myNewXref, string myLyr)
            Old = myOld;
            OldXref = myOldXref;
            NewXref = myNewXref;
            FoundOld = File.Exists(OldXref);
            Lyr = myLyr;
        #endregion
using System;
namespace Acad1
    public static class Class4
        public static void UsingTransaction(this Database database, Action<Transaction> action)
            using (Transaction tr = database.TransactionManager.StartTransaction())
                try
                    action(tr);
                    tr.Commit();
                catch (Exception)
                    tr.Abort();
                    throw;
        public static T GetObject<T>(this ObjectId id,
            OpenMode mode = OpenMode.ForRead,
            bool openErased = false,
            bool openObjectOnLockedLayer = false)
            where T : DBObject
            return (T)id.GetObject(mode, openErased, openObjectOnLockedLayer);
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Replies (0)
